What batteries are you using Cemetery?
An eagletree would help as well, you can also try the 3S pack with the lipo cutoff disabled. |
Bye:018: |
***RC***, I don't think having any oil in the centre diff should cause it to lock up while coasting like you said, since if your coasting then the front and back wheels should be spinning the same speed as each other and the gears in the diff should only be spinning when the two outputs (shaft to front diff, and shaft to rear diff) are spinning at different speeds. If the gears inside the centre diff lock up it would just be like having a spool or a solid shaft (front and back diffs will get the same power), but it won't stop the car from rolling.
Is it possible that the ESC is simply misfiring the wrong coil once in a while?
Alright guys, I think I'm going to attribute this problem to radio interference. Even though I have tried two different radios and 3 different channels. Also, the glitching now happens on 2s, 3s, and 4s, so it has to be interference. I also did a test without brakes and it would not slam the brakes but would go into neutral instead.
All these tests were done in front of my house, so last night I went to a parking lot about a mile away from my house. I was there for about 20min and it only glitched about 4 times. I still don't know why it is doing this, I think I need a 2.4GHz radio... Also, this problem suddenly came about almost a month ago, it never happened before. In my area I used to get interference on AM radios, but never FM until now. I cant figure this out. Quote:
Bye:018: |
Well, I tried the buggy again with my new DX3.0, and it seems to be working perfectly. I also rebuilt the center diff, but Patrick said that wouldn't help, so I am assuming the 2.4GHz radio helped a lot. I rolls freely and doesn't lock up how it used to.
yeah, if u guys dont have a dsm 2.4 ght's setup, u NEED one for bl suff
makes driving soo much more fun |
Well, after not getting any sale hits on the CRT.5, I decided to re-do it. Actually, I did get one potential buyer, but found a few things wrong, so I backed out.
The goal for the rebuild is going to make things MUCH lighter and lower the COG. I already took about 20% of the unneeded material from the motor mount, recreated the ESC/rx tray/CD brace, and started making a new battery tray. Still aluminum, but more thought going into the design to reduce weight. I plan to run a Medusa 36-50-3300/MM on 3s. I'll also be using the DimensionEngineering ParkBEC (tiny 1.5A version) - this BEC works perfect on the Slash, so it should be perfect for the CRT.5. I got the ESC, motor, and BEC in the mail today (thanks Mike!). Gonna start looking for a 3s lipo with between 2500mAh to 3500mAh. Anyway, after I pulled all the old custom pieces out, I decided to refill the F/R diffs. I had never touched them from stock so it was time. Man, there was hardly any fluid in there! Just enough to lube them and that's about it. Either that or I have a pretty good leak - which is not likely judging by the lack of goo near the outdrives. While I had the diffs apart I noticed the steel bevel pinion gear was broken in the front diff. The little sleeve literally broke off the rest of the bevel gear. I looked a little closer at the rear diff and noticed you can push/pull the outdrive about 1mm in the diff. Maybe that slop caused the break? Who knows. So, I decided to add a shim to the outdrives (on top of the o-ring and under the pin/gear). I have one, but need 3 more. The LHS is looking but is having difficulty finding them. So, does anyone have any 6mm ID X 14mm OD X "really thin" diff shims they are willing to part with? Or a link to get some somewhere? I look at various places and can't find them. |
Brian,
Have you checked McMaster Carr on those??? I'm out of the state currently otherwise I'd check my parts stash for you... Pro. btw...my CRT.5 build starts next week. |
Did you happen to notice that the shims are free? Weird... ProCharged: I thought of MMC, but I would have to order other stuff to make shipping worthwhile. Sucks to pay more for shipping than the cost of the part! |
Brian - You're gonna really like that Medusa in there. That's what I finally settled on in mine and it runs really well. The MM handles the 3S quite well using the internal BEC. I don't recall exact temps but I know it wasn't even an issue the last time out at the track. With the external BEC it should be even better. Keep us posted on the re-build!
I hope so. It's more than I wanted to spend on something I was planning to get rid of. I like the 36-50-2200 Medusa in the Slash on 4s - it runs MUCH better/cooler than the 5700 did, so I expect good results with this setup.
Lol, the only "cheap" motor I am using now is in my e-Jato (CC 4600). Everything else either has Neu or Medusa. Man, once you go with a better quality motor, the Feigaos just don't cut it anymore! :smile: |
Lol, I got my replacement spur from Nitrohouse, but the "free" shims didn't arrive. I called them and apparently they aren't free. They updated their price and will ship them out (for free) if I pay for them. Oh well. :smile:
FYI: The shims come 5 in a package |
Update
I had placed the CRT.5 for sale but there were no takers, so I figured I would redesign it.
First off, there were several goals I wanted to achieve:
Now for some pics: The new battery tray. It's hard to see, but I JB-Welded the chassis openings to keep rocks and stuff from hitting the lipo. Then, I added a layer of lexan to further shield the pack. The hole in the tray is to access the tray mounting screw: http://scriptasylum.com/forumpics/crtp5_newtray.jpg And some of the typical pics. Don't mind the crappy electrical tape on the motor - that's temporary: http://scriptasylum.com/bl_conversio...crtp5_v2_1.jpg http://scriptasylum.com/bl_conversio...crtp5_v2_2.jpg http://scriptasylum.com/bl_conversio...crtp5_v2_3.jpg http://scriptasylum.com/bl_conversio...crtp5_v2_4.jpg http://scriptasylum.com/bl_conversio...crtp5_v2_5.jpg |
LMK |
I opted for the RC-Bros/Smokey Racing BL converion kit...since I'm the Senior moderator there and because Mike (surprisingly) never responded to my emails.
Looks nice. I hope to post pics of mine next week.
Pro. |
| All times are GMT -4. The time now is 03:11 PM. |
