I took this out for its first shake-down run and everything looked good. I ran it for 5 or so minutes - lots of power from the esc/motor combo on 6s. :yes:
Here is the set-up I'm running: Castle xo-1 1717 motor (1650kv) EZrun 150a Pro esc 2x6s Gens Ace 4000mAh 25c in parallel Hostile MX fronts all around Muggy gearing (45/11) 50t spur/14t pinion Here is the top speed estimator: Quote:
It must have felt so good to finally pull the trigger on this bad boy!:yes:
It looks awesome, congratulations on a great build.:yipi: Get that thing dirty:intello: |
Any videos:whistle:
The car came out great, I hope it drives as good as it looks:yipi: Thomas G |
Another test run - I need to tune the suspension a bit - I'll start with some thicker shock oil to try to make it less "bouncy" with the stiff 5ive-T springs. I probably have a bit too much toe-in as well. But here's a quick video so you can see how it looks:
<iframe width="420" height="315" src="http://www.youtube.com/embed/Umu7kPsWJbs" frameborder="0" allowfullscreen></iframe> (and thanks to Daniel, my 7-year old, for taking the video) |
You got a good camera man there, especially for his age!
I was reading back through the thread and I noticed the lexan you put on top of the shock piston for the variable damping. I like the idea and will experiment with it on my build. It probably helped alot when using LST springs on a fairly heavy rig as it adds compression damping without effecting rebound much. But I wonder if now the springs are strong enough to not require that added compression damping and placing them under the piston to add rebound damping. I'm sure you probably had this thought and obviously more testing would be required before coming to any definite conclusions. Just something in head. Thanks for the update, love the build and I'm really curious as to how the springs/damping part works out. |
Great camera work from the little one!
And I guess the truck isn't half bad either... :whistle: |
Thanks for the kind words - and I'll pass them along to Daniel.
I guess it's been a while since I've done anything with this truck (busy couple of months - I'm starting a new job, will soon be moving, etc.).
Anyway, I put thicker shock oil (30wt) in the shocks and it handles much better. I might even go thicker. The electric brakes on the HW esc are very strong - I did a front flip when I slammed the brakes on today (I think I have them programmed to 50%, but I'll have to check). But this truck is running pretty well. |
Haven't checked back on this thread in a loong time, gotta say it finished very nicely !
Great work Brian. |
i gotta agree with bondo there brian....nice work on the fabbed parts.
a great looking truck :intello: chris |
Thanks Chris - just wish I had more time to drive/tune this thing.
I do think the 1717 is a great motor for something this size - I still can't believe they released the HPI 5SC Flux without it! |
I hope Castle doesn't get beat up on 2200kv and/or ESC issues from HPI under motoring that thing ?
BTW Brian, Have you seen all the fab work I've done on my build ? I think you'd appreciate it since you like to make from scratch like myself. |
| All times are GMT -4. The time now is 11:54 PM. |
