I just took another look for our friend briang(see other post). I carefully counted only two banks of 6 fets. They were placed in the same place as the 80A, but there were only 12 of them. I could not remove the heatsink - it was glued there, all visible chips were the KIA78D05F (looks like a regulator/power transistor) and a uC whose numbers were filed away. The layout was almost identical to the 80A (see briang's post) and the fan has 4 hex nuts which just screw (barely) into the heatsink..I got to find a way to keep the fan on.... The rubber seal also is useless because there is a hole there...I doubt it really can compete with the mmm, but I'll give it a try someday - it is my backup esc anyway.
36?? I only counted 18 on the MMM. Then again, I haven't taken apart my V3 for fear of damaging the warranty.
only 18 fet's....i always thinking that this beast had more than 18 fet's:whistle:
Picture of MMM without heatsinks: (Sorry -- took the picture with my phone, not very clear....) http://i37.photobucket.com/albums/e92/pdelcast/test.jpg |
hey patrick, any 6s batteries come to mind for racing a rc8/1512 3D? currently running some neu 3200 xp's but the tech @ castle said they were a little too small.
And for those who might be interested, here is a panel of 20 MMM boards, with a single X-OUT circuit (bad circuit detected by test machines, and left unpopulated.)
http://i37.photobucket.com/albums/e9...t/IMG_0039.jpg |
thanks for the clarification Pdelcast!!!!!like ive said so many time the mmm is a powerful esc:yes:
Thanx! |
so there not a big difference(in fet's number) between the mamba max and the mmm... why the monster it is a lot more powerfull???
That's some really neat stuff you're doing there. I think I could just get lost on your side of the street. I want to learn more, that's why I ask so many questions sometimes. :yes: |
The Monster is also capable of double the voltage of the Mamba Max, which doubles the power handling capability. ALSO, the FETs are better today than when we designed the Mamba Max -- so the current version of the Mamba Max can handle more power than the original. (the number of FETs is a bit of an overkill on the Mamba Max.) |
The MMM build is almost fully automated then eh? Pick and place for the bullets? I would guess you put on the heatsink and case by hand.
Power wires are soldered by hand, cases, labels, heat sinks, fans, etc. are all placed and assembled by hand. |
thanks again.Pdelcast.. dont forget guy'sjust use the right pinion and spur and see what happen:whip: |
| All times are GMT -4. The time now is 03:32 PM. |
