-   -   Ofna DM-One Brushless Conversion (DM-1) (https://www.rc-monster.com/forum/showthread.php?t=8236)
jhautz 01.15.2009 03:40 AM
Still running the 2 speed in mine. Works great. RCMonster even makes a 2 speed pinion adapter now so you dont have to make your own like I did back then.
RCmonster Mike built an InfernoGT last fall and used the 2 speed also.
EDIT: In post number 85 in this thread there is a short video of the car running and you can hear it shift. The pitch of the motor and gears changes when it shifts. Its like a little turbo boost kicking in.
dangerwr 01.15.2009 11:57 PM
A couple of photos of the DM-1 Spec conversion . . .
Here we have my latest creation. I am using the solid spool with the center shaft and out drives from the 2-speed. Also, I started with a Novak conversion kit but am abandoning this idea for a RCPD top plate and motor mount with a RC-Monster battery tray.
My current plan is to use a MMM v3 :sarcastic: and a Neu 1512 1.5D/F. I think I will gear this 3300Kv motor at 14/51 on 4S to start and see how things go. Hopefully they go fast!
Oh well, it will be several weeks for the RCPD stuff to get here so this will be it for a little while. I might anodize the parts red if I can piggy-back an order from work. Cheers!
http://i88.photobucket.com/albums/k1...C/100_4915.jpg
http://i88.photobucket.com/albums/k1...C/100_4918.jpg
http://i88.photobucket.com/albums/k1...C/100_4917.jpg
year1camaro 01.16.2009 01:11 AM
I made my pinion adapter also. I probably would not have bought it even if I knew about it.....I'm into the fabrication end of this hobby. I also made the top plate and motor mount. It's cool to hear your not having problems with the 2 speed,,, that was a concern when I started this project. I watched your video, very nice...looks like it works great!
BL_RV0 01.16.2009 10:49 AM
Nice start man! Keep the pics coming.
ssspconcepts 01.18.2009 04:01 PM
Brushless OFNA DM-1 SPEC: Flightpower 5S 5000mah (25C) Battery, Mamba Monster Speed Controller, Neu/Castle 1515 2200kv motor, 51T Mod1 Spur gear, 25T Mod1 pinion (I know this is too big...but its fast as heck and fun), and Spider Eight 43/13 ring and pinion differentials.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 25
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 4.17
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.04 : 1
Total Ratio: 6.74769 : 1
Tire Circumference (inches): 13.1 inches (332.75 mm)
Total Motor Speed: 40700 RPM
Vehicle Speed: 74.83 mph (120.2 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
As promised here is my amature video...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/PA-RFKZg02A&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/PA-RFKZg02A&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
ssspconcepts 01.18.2009 06:48 PM
Here are the latest pics with the one speed direct drive installed.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/B-9EeARPZkoEcOyOYhLtHQ?feat=embedwebsite"><img src="http://lh6.ggpht.com/_Go2PcH5NPr4/SXOwiiCkS5I/AAAAAAAAC3E/vRxRO6T0JN4/s800/SANY0171.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/ssspconcepts/DM1Spec?feat=embedwebsite">DM-1 Spec</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/EQhSUDJrMVXc60qfh-jq0A?feat=embedwebsite"><img src="http://lh6.ggpht.com/_Go2PcH5NPr4/SXOwk42r0qI/AAAAAAAAC3M/QghrQ4Ja4uU/s800/SANY0172.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/ssspconcepts/DM1Spec?feat=embedwebsite">DM-1 Spec</a></td></tr></table>
dangerwr 01.18.2009 06:58 PM
Man that thing is fast--looks very powerful on the 5S. Do you think it is capable of going 70mph with your current setup? I can not wait to finish mine up!
ssspconcepts 01.18.2009 07:05 PM
The calculations say it is possible to go 70+mph:surprised:...but I never could get it up to full throttle because the tires constantly break loose. Towards the end of the video there were a couple of passes where I was close to full throttle but not quite. I absolutely have to get a radar gun. I keep talking about it but I keep spending my $$$ on car parts!
By the way...I see some other folks on here are installing one-speed centers. This was a PITA to keep the DM-1 center shaft from sliding back and forth because there aren't any bearing stops milled into the shaft. Brian helped me come up with the idea to make a shim using 8.1mm inner diameter stainless steel tubing and a couple of 8.1mm innerdiameter washers. It worked like a charm. I still have some of that tubing if anybody needs it. If you order it from onlinemetals.com they charge an arm and a leg for shipping.
dangerwr 01.18.2009 07:26 PM
I bought one of those Hotwheels radar guns off eBay for $20 and works pretty good! I am going to gear mine around 60mph at first and see where the temps are with my driving style.
Now, on the solid center spool I wound up using the center shaft and outdrives from the 2-speed that came with the car and not the little kit. Did you do the same or did you do something different?
ssspconcepts 01.18.2009 07:33 PM
Yep...had to use the 8mm DM-1 Spec center shaft...that's why you will need the 8.1mm inner diameter steel tubing.
dangerwr 01.18.2009 07:48 PM
I see--would you mind sending me PM with how much you would like for some of the 8.1mm tubing? I might have some in our machine shop at work but highly doubt it will be the exact size. Just let me know . . .
year1camaro 01.18.2009 10:50 PM
[QUOTE=ssspconcepts;253388]Brushless OFNA DM-1 SPEC: Flightpower 5S 5000mah (25C) Battery, Mamba Monster Speed Controller, Neu/Castle 1515 2200kv motor, 51T Mod1 Spur gear, 25T Mod1 pinion (I know this is too big...but its fast as heck and fun), and Spider Eight 43/13 ring and pinion differentials.
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 2200
Motor coil Ω: 0.006
What tires did you use for this run? Car looks fast fast fast!!! nice...Now to get it to stick to the road might be a challenge with all that power.
ssspconcepts 01.18.2009 10:59 PM
I actually used the stock treaded tires and wheels that came with the car. I am hoping that this summer (when it is 100+ degrees outside) that the tires will stick better.
dangerwr 01.18.2009 11:02 PM
I bought some Kyosho slicks myself but have yet to try them but they are very sticky! Kyosho makes them in 3 different durometers--45, 55 and 60 Shore A. I put some on the roller and the car literally sticks to what ever surface I place it on (aside from the carpet!). I think these tires are going to be the best bet for getting these cars to hook-up.
year1camaro 01.18.2009 11:04 PM
ahh, yes heat will help. Those are the saem tires that came on my gtp,,They are ok,,,but I wasn't to happy myself. I'm tryin out the foams on my DM hoping for better results......Was that an actual torque roll at the end of the video?
