I haven't opened yet freshly arrived unit from China... |
What are you having done to the Jazz40?
So, higher amp and/or voltage handling?
I do not know guys, but whoever wrote this firmware was really up for something...<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
<o:p></o:p> I was unable to sync Jammin's ESC to anything at all, just blinking LED no beeps no nothing, but I do have brakes :)<o:p></o:p> <o:p></o:p> Opened unit number 2 and it beeps, spins and does whatever it wants but none of what I expecting to see...<o:p></o:p> <o:p></o:p> Is it possible to set it all? I ditched everything and start playing with Traxxas transmitter (what can be simpler), trying to reverse channel, 30/70, 50/50 splits it just doesn't make sense. I guess I will try next weekend, what a bummer.:diablo: http://forum.rcdesign.ru/index.php?a...ntry&id=159805 http://forum.rcdesign.ru/index.php?a...ntry&id=159804 http://forum.rcdesign.ru/index.php?a...ntry&id=159803 |
Maybe that brain board is for the aircraft controller. I know some of the car controllers found in the forum and the one I have, the brain board is red in color and the aircraft one is green and you can see them in the pictures I posted. Do you have the program box? You can also try and calibrate the controller. Try one of the following:
1. --no need to set up Throttle itinerary ---- startup process pull throttle into the lowest position -- → ESC power connecting → Detect and get throttle signal one beep tone "beep" → 3 seconds delay → detected throttle lowest position → one beep tone "beep" again → can start throttle Moved.( start flying). this step total beep twice . there had light on ESC when each beep tone . If not detected throttle signal, "beep, beep and beep ... " continued beep tones are emitted. If the battery voltage exceeds voltage, "BEEP, BEEP, BEEP ." continued beep tones are emitted. the beep tone pause for a bit longer,Under such circumstances, ESC refused to start motor. 2.need to set up Throttle itinerary ---- startup process pull throttle to the highest position -- → ESC power connecting → Detect and get throttle signal one beep tone "beep" → detected maximum throttle position, "beep" tone is emitted (one beep tone) → then pull to the lowest throttle position → 3 seconds of delay → "beep" tone is emitted once, Detected the lowest throttle position → can start lifting the throttle. three beep tone is emitted . Note : This method set up the throttle itinerary is not saved. throttle itinerary can be set up and saved permanently by our programm card. |
Finally, with your help, I have something under control. Still need to be armed every time you power it Up but I can live with that for now...<o:p></o:p> Now back to Frankenstein, updates will follow... |
I am not happy with that ESC in general...<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
Is it operational? Yes and kind of no, I do not like how it works.<o:p></o:p> <o:p></o:p> Luciano what you would like to do with that "cheap" (not really) ESC?<o:p></o:p> <o:p></o:p> No comparison to MM neither in price, quality or features. I even put BK on top of it not even mentioning schulze. Anyone would like to have this combo can shoot me PM, I have spare one. |
| All times are GMT -4. The time now is 07:57 AM. |
