The second reason is for marketing reasons. :tongue: |
I don't have any plans right now to offer without a fan. |
I really don't see everyones issues with the fans. We use them in our computers to keep processors cool, we use them in our cars to keep engines cool, we use them in our houses to keep us cool. They're fantastic devices used the world over to keep things cool both electronic and not. Why is that some have it in their minds that a "properly designed" ESC should stay cool without assisted air movement? What is the real detriment of having a fan?
One big reason I like the fans is that it allows me to mount the ESC without so much consideration for air flow and especially in Texas heat keeps things operating better. |
operating an RC vehicle in a dirty enviorment is much different than your computer in your home I dont use any fans on any other of my RCs and dont have any heat problems, I would like to see the option of being able to remove the fan similar to a plug in the RX...maybe have a mini plug in the side of the ESC
I have operated mine with fans in dirty environments without adverse affects so I still don't understand. If the fan is quality and the motor protected how is this different than running any other electric motor in dirty environments? Every racing vehicle on dirt tracks and mud courses uses electric fans in there cooling systems as well. Not too mention military and construction vehicles as well.
I dont have any issue with fans like I said before- so long as they are used as a substitute for normal airflow, instead of as a forced-cooling unit, its fine be me. I'd like to see a better fan on the MMM, buts thats in hand I gather. |
Trying to get more of the crawling market huh? It will never work. You know that is such a small niche with just a bunch of grown men BSing on the rocks all day. :lol:
Can't wait to see if you have any programming tricks up your sleeves (like neutral brake for motors with little drag ability) or what kind of motor you will sensor up. I can't imagine you would just use a normal old two pole inrunner with a sensor, but maybe I am wrong. |
Patrick, I am not sure that D2-Pak7 has smaller die than SO8-FL and its current ratings are not that shy. And I agree on SO8-FL vs. LFPAK's.
Personally, I am looking forward to use DirectFET package, you can heatsink them top&bottom equally. For 30V ESC. I do not see why software can be so complicated, 10 years ago maybe it was an art to make brushless sensoreless, today with all bells and whistles inside micro's and all the features... Cannot believe in that... Neither I have seen chinese ESC with as smooth performance as schulze... Nice plans for: 8S 200A ->6720W 12S 125A -> 6300W 8S 325A -> 10920W 12S 200A -> 10080W Just keep wondering what kind of capacitor (size wise) you are planning to use to absorb punishment. Even 2% of 6kW would be 134.4W - that is pretty good size for capacitor...and 2% is nothing you know. Or you plan to have batteries implanted inside fet's :) - :lol:Did somebody said something about sensors ...Hmm - > Marketing or Hype -> must be crawlers :diablo: |
Heck, I'd like one of those Mamba Max Pros for my TT-01. I have an SS5800 that I want to run 3s lipo on since it has the 12mm sintered rotor.
Patrick, what are the ratings on the Mamba Max Pro in terms of current capability (are we looking at a sidewinder type capability here, or something between sidewinder and mamba max)? Can you give out a number or a percentage of what it is in regards to the Mamba Max's 100 amp rating if you don't have an exact number? |
However, SO8-FL has larger silicon-footprint ratio than D2Pak The DirectFET is a great package -- but IRF silicon sucks. (Infineon is releasing some DirectFET mosfets soon...) Quote:
Ok, I will try to come up with software, you convinced me :) Done that in the past, so not a big deal, as you said hardware is relatively simple :) See, I was hoping you write software, I will do the hardware - the output stage...and then even open source it -> deep inside I think it is the hardware which is complex. Software only become complex, when has tons of bandages and solutions to overcome hardware flaws not limits, limits must be identified at the design stage. |
Well, give it a try. I think you will find it is MUCH more complex than you think... But isn't everything like that? It looks easy from the outside, but when you actually do it, you find it is much more difficult than you first thought. And it's not bandaids either -- just the core software is very complex because of the number of possible states. There aren't any "bandaids" in our software to overcome hardware flaws or limitations -- it is usually easier to mod the hardware than the software.... Why do you think there aren't any "generic" hardware sensorless brushless controller chips? All the hardware chips out there require tuning to a particular motor, and they still don't work well -- And Infineon isn't releasing a new package -- it is the DirectFet package, licensed from IR. Mainly because IR is still behind in the MOSFET arena -- and IR doesn't really have enough fab capacity to handle a lot of new business anyway. |
I mentioned it before about Castle having their own MOSFET. Most foundries will be more then glad to do it if you can place orders for a few million MOSFETs. You can also talk to IRF and let them know you will be making your own silicon and want to use their DirectFET casing. I know it might or will be difficult to do, but could be worth it.
Edit: I think Infineon already has their DirectFET, it's acalled CanPAK and they come in a M and S size. |
- No need, RC market not taken seriously. - Than it is not silicon, but process or both, wierd nice package old technology?!. Even if it is licensed, still require break-in and tuning. It is new technology for the fab. |
| All times are GMT -4. The time now is 02:05 PM. |
