How do the weights of the actual buggies compare as rollers? I know they are similar (Kanai III vs 777), but I wonder if different parts make the Kanai III heavier.
MetalMan, my Inferno 777 SP2 (nitro) weights 7 lbs 12.4oz (no fuel or rx battery). The Kanai III (brushless) weights 7 lbs 12.6oz (with no battery). So like I said most of the weight difference is in the lipo battery.
Non-Stock parts: 777 SP2: Fioroni shock towers, Steering plate. Reckward chassis braces, CEN CNC knuckles, CEN 16mm Big Bore shocks/RMV progressive springs. Kyosho bonded brakes. Kanai III: Racers Edge shock towers, Racers Edge Toe in plate, King headz chassis braces, Knuckles and C-Hubs. CEN 16mm Big Bore shocks/RMV progressive springs, Craddock fiber rotors, K-Factory hinge pins. King Headz steering plate. yeah so there is a lot of extra aluminum on both buggies. I went for a little extra durability over super light weight. |
Here are some pictures of the track where I will run the test and some of the Racers that show up for the bigger events.
http://i142.photobucket.com/albums/r...413/Image1.jpg Jared Tebo and Travis Amezcua http://i142.photobucket.com/albums/r...3/DSC03199.jpg Masami Hirosaka 14 time champion, check out that stick radio. http://i142.photobucket.com/albums/r...3/DSC03181.jpg Mark Pavidis http://i142.photobucket.com/albums/r...3/DSC03177.jpg The track, the layout has since changed since these pictures were taken. |
Nice.
Hey nice track and quite a crowd as well. Looks like a fun place to run with loads of compitition to keep you busy. Plus you can get a lot of "word of mouth" advice for whatever is on your mind.:lol:
My X-rays are 7lbs 15oz for the Brushless (including 5s 4350mah pack) and 7lbs 7oz for the nitro (then add an estimated 5oz for a full tank of fuel) so 7lb 12oz with a full tank.
Without the Lipo the brushless is 6lbs 11oz. |
my 2 xrays weigh the same with a neu 1515 and a 4s 3700 pack and rear mechanical brakes
| All times are GMT -4. The time now is 01:38 PM. |
