-   -   Lipo Battery Standards, open discussion (https://www.rc-monster.com/forum/showthread.php?t=11737)
lutach 05.01.2008 08:37 PM
Long term test would be good too. It might take long, but would help to see at what cycle the cell(s) starts to loose some capacity.
hoober 05.02.2008 01:38 PM
I personally like the CBA graphs at various "C" ratings. Various current ratings are even better. To keep it simple a single cell should be graphed at the various currents and a temp rise and max put in description at each current.
I like to look at th graph and make my own interpretation as to what I would "rate" the cell at.
Doing packs opens up another can of worms, but is far more realistic. If someone wants to discharge a certain pack at a certain "C" factory rating it is nice to see the results.
Arct1k 05.02.2008 01:49 PM
Question - Is it worth plotting charts under varying load - sign wave? - In real world you will hardly every draw constant ampage. I wonder how well different packs take this.
BrianG 05.02.2008 02:22 PM
Personally, a graph using the testing procedures found in my previous post is best. It's not perfectly ideal, but should encompass the worst-case use a lipo will endure. At the very least, it will rate all cells using the same conditions and procedures for a better apples-to-apples comparison.
aqwut 05.02.2008 02:35 PM
Yeah, that would be nice... Worst case scenario would be best.. I like it when batteries are underrated.. I usually underrate them myself by about 20% when figuring out speed, power, voltage & capacity.... It's always nice to have a battery pack that can perform whatever is marked on the sticker.. without any fine prints.. but I guess that would be hard to do..
LOL, I bet you'd love to be the person to perfom all these test... I know I wouldn't mind.. house full of LiPos, imagine that...
johnrobholmes 05.02.2008 02:57 PM
I think that both constant and burst testing will prove useful. The Constant rates will allow easy comparison between cells. The Burst rates will allow the true ability of a pack to be tested and empirically logged. Even 1/10th second bursts could be used to get an idea of how high a pack will spike before dropping out.
lutach 05.02.2008 02:58 PM
I can definitely tell which one is good :lol:. If they can handle our stuff, they can handle anything. A video of the test should also provide some form of where the data came from. A burst test should be done to confirm the pack can withstand the burst rating. Afterwards one should be able to establish a safe continuous and burst C rating on their own and not just go by what a factory puts on the cell. It all comes down to a little commom sense on the rating of cells and to avoid situations like the ones mentioned. All the batteries I've tested and owned does come with a factory C rating, but I like to beat them up a bit to see if they can live through it.
BrianG 05.02.2008 02:58 PM
OK, so who's gonna spring for the equipment and begin testing? :smile:
BrianG 05.02.2008 03:00 PM
It just sucks that we have to do a live test to see. It would be nice to know the true capabilities before they puff. ...Kinda like testing to see if food is poisoned by tasting it. :lol:
lutach 05.02.2008 03:10 PM
If I had a CBA, that's what I would do. Then people wouldn't have anything else to say. Who knows where those graphs came from. I can get you great graphs from Enerland, change a few things here and there to make it seem like it was done by me. Make a video of the test doing the 1C, 10C, 20C and burst ratings. That will definitely be the most effective way for me.
DrKnow65 05.02.2008 04:55 PM
How about a graph where the cell is loaded to what ever amps it takes to drop it's voltage to 3.2v. Then as the test progresses the amps will fall off to keep the cell at 3.2v untill the amps hit 0. Note the temp rise from an established 80*f. Cutoff voltage may need to be higher or lower for the cell to never pass the "maximum safe" temp ~140*f?
It would of course take multiple tests to place the proper cutoff voltage with each cell. Example cell#X test 1, LVC=3.8v (test begins) tester loads the cell to what ever is necessary to drop the voltage to 3.8v (say 60amps then decreasing, dictated by LVC) cell temp only rises to 115*f during the test. Recharge cell to 4.20v cool it to 80*f. Cell#x test #2, LVC=3.6v (test begins) tester loads cell (say 85amps then decreasing dictated by LVC) cell temp rises to 135*f during the test. Again at 3.55, 3.50, 3.45---
So on and so forth untill either the max safe temp is hit or the LVC drops below 3.0v. At that point a graph is made, showing the cells maximum constant performance.
The variables for air flow would need to be set, and a tester would have to be fabricated. We could use a data logger to show the volts, amps, time, and temp in a graph.
Wouldn't an ESC with a soft cutoff (proportional to lvc) be able to do this for us? We would just need a load that will be able to stay constantly above the required amp draw.
BrianG 05.02.2008 05:10 PM
Exactly. Do the test for several C points like how I originally stated. Eventually, you'll find the C rating that maintains the minimum voltage you are looking for. Some people may find 3.0v an acceptable cutoff, while others may accept only 3.3v as the cutoff. The graphs would show this and allow people to make informed decisions.
Then, compile all the graphs and make a little datasheet just like how electronic components are rated.
I don't know about other people, but my goal would be to provide the information for buyers and let them make the decision about what is adequate for their needs.
johnrobholmes 05.02.2008 05:21 PM
When finding the constant load on a battery with voltages as low as 3.2 or 3.0, we should find that the capacity does not hold up to the 90% standard. Drawing a battery at a rate that depresses the voltage to 3.1v/ cell average should make it fall out at a terrible capacity.
BrianG 05.02.2008 05:26 PM
Well, the graphs would show that as well. The end-rating would take that into account, but the graphs would detail it out.
johnrobholmes 05.02.2008 05:30 PM
Yep yep. It will show the constant rate that drops capacity below 90%, or that falls below 3.X volts/cell average.
My question is whether there will be much variation from brand to brand. Since all lipos are made with similar construction there should be a fairly close trend on now far down the average V can be pushed before the capacity drops significantly. Of course inferior brands or brands with new manufacturing techniques may be able step outside of the norm. This has been a question of mine for a long time actually. Are enerland cells showing higher average V on continuous capacity only because they rate them conservatively?
