Thanks for the email addy lutach!
The c50 maxx uses a s can length rotor in a l length can. Basically gets higher rpm from using the smaller rotor. You could buy a l can rotor and put it in the hacker, which should give you around a 2000kv motor. The windings appear to be a 13l, but the lighter, smaller rotor ups the kv rating. Do you know what the l length rotors cost lutach? |
I have a 13l, 14l, and an 8l, and the 8l has much thicker wires coming out of it. |
Thanks a bunch lutach. Thats the first upgrade I plan to get for sure when I get the hacker.
One more question... Ive heard that the feigao L series rotors will fit into the hacker c50 motors. Is this true?
Hmmmm... Good point! I will keep an eye on the hacker 5mm upgraded rotor as well.
Got an email reply, here it is:
James, Yes we do sell a rotor that is 5mm in size for the C50 Maxx motor. The C50 L rotor will not work with the C50 Maxx motor for it has a special magnet length. The 5MM rotor would be $75 Best Regards, Kyle Bergstrom Aero-Model/Hackerbrushless USA Repair Dept. Manager www.hackerbrushless.com www.Aero-Model.com 2122 W. 5TH PL. Tempe AZ 85281 |
Wow. I should reply to Kyle now and see if he still can do his $50 for the rotors :lol:. Good thing I save most of my e-mails :lol:. Might be because I was going to buy 2. |
This is just an observation.. but a $50.00 motor which will require a $50.00 upgrade and will STILL be a very high kv wind if used.. Doesn't it make more sense to just opt for a Medusa Afterburner instead?
| All times are GMT -4. The time now is 08:35 PM. |
