I wouldn't even consider a fan unless my ESC ran 180, I had tried everything to lower it and had no success. I run in Houston (yeah, where the real summer is) and I've not had ANY heat problems EVER running 2S. Putting a fan on a mamba 2S system is just laughable. I guess if it makes you happy, go for it. |
Well I had to put a fan on mine. I ended up buying another brand new one and swapped them out and put the deans connectors on just to see if that may have been a issue. Same thing, up around 200 degrees within minutes with all my settings as low as they go. I put the novak fan on and temps were around 130-140. Ambient temps here were 72 degrees when running. I am running a Tekno Neu, 2s 8k lipos, (4s), 22/58 gearing, CC BEC.
its only 72 degs....when I wake up @ 0700 its pushing 90 degs here....:-0 |
Anyone know what the CFM is on the standard MMM fan?
I found a 5v 30x30mm magnetic levitation fan that I have on my MM running 4s with a Neu 1515/1.5d.This fan puts out 4.9 cfm compared to a novak at 2.5cfm.
Also a question, I just manage to ARM my MM with 16.5V (5S a123) even with a custom Voltage cutoff :) anyway, do you think I can use the red wire from MM to power the fan (only) and still run 5S A123? |
http://img380.imageshack.us/img380/5...2225617lf0.gif |
Thanks for the Fan info. For the Fan power source I also use the Rx but I was hoping to use the BEC of the ESC since its just a small fan but I guess it will be safer to jsut use the RX to power the fan
Heres a photo of my 30mm Magnetic Levitation fan on my MM.This little baby puts out 4.9cfm.:whistle:
http://img401.imageshack.us/img401/1...4096ck4.th.jpg |
where can i get one of these???
How much does that cost and where did you get it from? |
$15-$20 posted i would get one... and hope it wouldnt break. anything more and i probably wouldnt bother seeing as i can get 5 and 12v fans for $7, sometimes with a cheapo heatsink!
are these available worldwide as ive never seen or heard of them before |
This is the page address its from buyextra.com:whistle:
http://www.buyextras.com/su30dc5vmale.html |
| All times are GMT -4. The time now is 01:38 PM. |
