Makes sense. A signal is a signal, it's the user input method that changes.
Did you try to flip the throttle cable around on the receiver? |
Is it normal for the ESC to get warm from calibrating it? I temped it and it is 114.
You need this!
Aux: None Thr: ESC plug in here. Str: You need a Y adapter and both steering plug going in here Bat/Tel: BEC plug in here Did you disconnect the red lead on the ESC lead - If not stop and do so now... before smoke! |
LMAO. Looks like I will have to wait another couple of days to get that y adapter for the steering........ Even then I will probably not be able to get it working..... Ready to throw it out the window.
For now just use one of the steering leads... and follow above
Okay I got it. Now I just need to get that adapter.
Not really - tad worried that you might be still using the interal bec - any chance of photos
Please post up details of your setup - Car, battery, motor, gearing etc.
If 4s then yes a ubec, fan and cap |
| All times are GMT -4. The time now is 10:28 PM. |
