-   -   Ordered a new ERevo (https://www.rc-monster.com/forum/showthread.php?t=14231)
bustitup 08.14.2008 10:37 PM
you have to be carefull on size of lipo's....those r's you linc to are to loong for a erevo by 10mm
RideIcon 08.15.2008 01:23 AM
hey, how do those traxxas battery terminals compare to the deans ultra?
Is there a rechargeable battery pack available or that can be fitted to the factory traxxas transmitter?
VintageMA 08.15.2008 09:35 AM
I don't know if I agree with that statement. e-mike is saying he is using them in his e-revo in this thread: http://www.rc-monster.com/forum/show...hlight=zippy-r
The TP packs at 160mm still have some room front to back. I actually had to move in the spacer to make sure they were snug.
bustitup 08.15.2008 09:44 AM
well then I stand corrected......I was going by the fact that the erevo bays measure 160mm and the batts claim to be 170mm long thats a 3/8" differance
sorry for the misinformation
suicideneil 08.15.2008 12:54 PM
http://s115.photobucket.com/albums/n...atterysize.jpg
RideIcon 08.16.2008 04:40 PM
Castle Creations Mamba Monster controller out of stock
how do i tell which 1515 neu motor i need? people say 1y, i see some are using 2.5d,
what is the difference? Would I always have to run 6s? if i run 3s for longer run times will it all still work?
monster put together an order for me of all the parts I need.
suicideneil 08.17.2008 08:33 AM
Depends what your goal is specifically.
A speed machine on lower voltage would need the 1.5d, but woud tend to run warmer and push the batts more.
A speed machine on higher voltage would use a lower kv motor, to give much better temps and runtime to boot.
Normal basher would be fine with the 1y on 4s, then stepup to 5 or 6s for speed runs and freaky power.
As for voltage- I would never say use 3s lipo for an MT. With anything other than the fastest 1515 sized motor it wuold be slower than old people humping, and if you then stuck 4/5/6s to the same motor... hot hot hot.
RideIcon 08.17.2008 02:10 PM
If I only use 6s, whats the motor to shoot for? stupid fast!
I'll just buy a couple extra batts and a nice charger
will rc-monster get that controller in soon?
Taylor 08.17.2008 08:42 PM
so what would that nue 2.5d run at? :neutral:
ReV:-O 08.17.2008 09:23 PM
how much runtime are you getting with those Thunder Power 5000mAh packs?
RideIcon 08.18.2008 12:34 AM
ahhhh i dont know...
im asking you guys.... lol
Ive got the money to order the esc and motor... which motor am i shooting for? 2.5d? 1y? gah......
ReV:-O 08.18.2008 04:31 AM
i'm buying an e-revo and i mainly drive on grass and pavement. i have a lot of space so i just want crazy speed.
im getting a MMM, Neu 1515/1y, and two Thunder Power 3s 5000mAh lipos.
That way, the motor will be spinning at 50,000RPM which i think is the MAXIMUM any Neu motor should run at, as its RPM limit is 60,000.
i should hopefully be able to get 55-60mph, and at least 20 minutes of running.
