why use dean....the 6mm will be better for your set-up??!!
i am taking the truck to my LHS tomorrow to look for connectors...they specialize in electric planes and cars!...6mm what?...this is my first electric r/c!...i have been nitro guy!!
The packs look like they could become damaged easy. The packs hang over the chassis almost a 1/2! I'll bet a pair of mikes battery trays would bolt right up and provide some much needed impact resistance.
no,i did not get it from BOOYA!....as far as i know this is the only chassis like this!....Virgil is making me a new mounting bracket for the steering servo!....it will be ready to run after the part is ready!....i plan on runing the LIGHTNING on 2-5s this weekend if the weather holds up!....i am also going to fabricate some new posts for the UE battery hold down kit to work with the larger 5s lipo batts(wish me luck):wink:...it should look very trick!
Here is where I saw that chassis for the first time:
http://www.bk-electronics.com/copper...&cat=0&pos=199 http://www.bk-electronics.com/copper...&cat=0&pos=200 http://www.bk-electronics.com/copper...&cat=0&pos=201 http://www.bk-electronics.com/copper...&cat=0&pos=202 http://www.bk-electronics.com/copper...&cat=0&pos=203 |
what guage wire are you using? it looks like 16 guage in the picture next to the 8 guage on the li-pos, and that doesn't look like sillicone wire either:surprised:. without sillicone wire, if the guage is too small and the current is too high, the insulation might melt... and that would not end well.
I thought it was big for 10guage, maybe they should use copper tab cells instead, maybe solder with a little silver mixed in? imo that's a better plan
and I think the zippy li-pos use china cells, polyquest is an enerland pack |
I assumed the polyquest XQ were copper tab? Theyre the latest polyquest packs I thought, with the highest discharge rating. But for some reason give slightly higher V drop under load (apparently.. none of this is confirmed by myself). I'd be surprised if any new lipos weren't copper tab to be honest. At any rate, if theyre not, they damn well should be! :P
I really hope they are, maxamps uses copper tab cells, but they don't use nice cells.
I like thunder power v2's the best, they're enerland packs. I hope this has copper cell tabs, cuz I'm getting it soon: http://www.amainhobbies.com/product_...ducts_id/17987 |
but really, plettenbergs what gauge is that wire going to the motor? you could be loosing some voltage with that stuff
| All times are GMT -4. The time now is 02:09 PM. |
