Why did the ccbec smoke?
well i have 2 things in mind
the first is i wanted to change the output v on the ccbec and it didnt work , i dont know if i needed a diff program from cc or ? although it was soldered to the esc. the batterys were not hooked up......... the second thing i was thinking was that i plugged it in and left the esc. switch off , then i went outside , i live in an apartment so the ccbec was on because the batterys were hooked up and it took about 2 min. for me to put the body on and go outside to run.....?? dont know , i just hope that the servo and rx are ok , they seemed to work good the second time i tryed to run until the esc. quit?? |
thats weird, if you managed to fry the ccbec, there is a chance you have fried the MMM bec in the exact same way, thats quite a coincidence, something must be wrong with your setup, like a short in wiring somewhere that you are not aware of may be. I've been running my V2 MMM flawlessly thru 6 packs so far with SportBec and fan wired to RX directly
well idecided to try one more thing before i send it back and it fired right up!!!!!!!!!!:party:
it links with usb so i left the red wire in and used a rx pack and it works i hope i will get some running with it as is for awhile , and wait to send it back |
Did you plug the rx pack directly into the battery port of your rx? What about the fan? |
yes , i just hope it holds for awhile , i want to run my truck so bad
she will get beat but good asap:rules: |
| All times are GMT -4. The time now is 04:27 AM. |
