-   -   My neu motor is very very hot.. (https://www.rc-monster.com/forum/showthread.php?t=14863)
BL_RV0 09.07.2008 11:59 AM
Why are you running 2 male and 1 female connector on the motor?
e-mikey 09.07.2008 12:03 PM
I think it's burnt. I had it covered up with electrical tape, and the front is covered by the motor mount/spur cover.
All male.
e-mike 09.07.2008 12:04 PM
could it be a a little chunk of stone who scratch the winding(betwin the magnet and the winding)
lutach 09.07.2008 12:45 PM
That looks exactly like a shorted phase. Don't run that motor again, you might damage other stuff if you do. Give Neumotors a call to get an estimate on price and turnaround time.
TexasSP 09.07.2008 04:57 PM
Next, if your motor ever goes over 200, check everything over for problems before using it again. I am with lutach as well, send it to neu and live with the piece of mind it will be fixed and running correctly.
REVO-DADDY 09.08.2008 01:22 PM
I knew I smelled bacon on Saturday. :na: Maybe you should stop halfway into the main and take a temp check?
I think I have my buggy worked out, wanna hit the track?
neweuser 09.08.2008 02:13 PM
Those burnt wires definately do not look like solder to me. Looks like a bad phase. I would send it in.
BrianG 09.08.2008 02:34 PM
It looks like something jammed the rotor (debris inside the motor, or just a really heavy load) and a stantionary rotor is just about a short - the only thing limiting the current to the motor is the ESC capability, battery capability, and wire gauge.
brushlessboy16 09.08.2008 05:07 PM
doesnt the MMM and MM have the auto-off feature when detecting a locked up motor?
BrianG 09.08.2008 05:10 PM
lol, yeah, it's called melted power/motor wires and/or blown FETS. :na:
lutach 09.08.2008 05:16 PM
Not fair 1 point away for hitting below the belt :lol:.
BrianG 09.08.2008 05:26 PM
lol, I guess any ESC is just a big fuse then, eh?
Edumakated 09.08.2008 05:29 PM
That motor is smoked. I did the same thing. Bad solder joint and it came off the track at 300 degrees with smoke pouring out of it. At some point it is going to fail if it hasn't already demagnetized.
Neu will replace the motor, but it will not be under warranty as the failure was caused by something other than workmanship of the motor. They have a good replacement program though. 50% off any new motor of your choice.
e-mikey 09.08.2008 09:15 PM
Isn't it kinda their fault for over tinning the wire?
