HI Capt,
Removed a few components related to the BEC & used a UBEC to power the MMM. Also removed the fan power supply & use the UBEC to power the fan. Regards, Joe Ling |
I have 2 working V2's still. The one with the most hours on it (several weekend worth) is one that the fan connector broke off of the first day. I cut the "grill" section out above the fan so the blades could not catch on it & wired the fan to the RX. This V2 has performed flawlessly since I did the mods after the first day. My set-up is 5S, Neu 1512 3d/f,RC8 18/46 gear. The other one only has a couple of hours on it. It still is using the stock fan & connector but I cut the grill out of it. I also carved some clearance in the case around the connector & but I'm thinking of busting the connector off the board on purpose. On both V2's I have put shrink tubing on the big plug sockets to keep them from shorting on the heat sink. I did have 2 earlier V2's fail but they were not modified (failed on the same set-up).
oh perth is getting lovely this time of year !! the weather is just in its prime atm , sunny spring days . dont be shy to shoot me a pm if your ever in town come race our private r/c track we have , you will have a ball on it !!
Hi mxracer,
Regards, Joe Ling |
Hi RBMike,
On with the torture...I mean testing :whip::mdr: Regards, Joe Ling |
Disaster !
I had my modded V2 die on me on Saturday. I was running as usual & it just stopped after the double jump. There was no LED & tone. No response when connected to the link either. Sad day :cry:
On the other hand, V1 in the buggy still going strong. Depleted another pack on Saturday. How much for an out of warranty repair ? Regards, Joe Ling PS : took revenge by running running all nitro on Sunday |
I believe USD70...I am about to send 2 of my V2 myself....
Hi TruckBasher,
I'm really bad at sending stuff in for fixing but I think I may be building up steam to have some stuff sent soon (target 1 month he he). I have a sidewinder that cannot see the PC & now a dead V2. I also have a dead Tekno neu that Impakt said to have it sent in but I was just too lazy... Anyway, went to the track again yesterday to run the V1 for probably half a pack & all was well save for the 3racing fan that I had just installed. I think it last only for 1 run. I noticed that it was not working prior to the session but ran the buggy anyway. Forgot to take temps. though. Regards, Joe Ling |
Joe, Same here, I have the 2 MMM boxed, labeled and waiting to be sent of to post office. :whistle:
You have one strong V1. I think there is only a few guys now running on them but there are still V1 out there. |
Ok, this is likely to be my last update. The V1 has finally also given up the ghost. In both cases, I think the vibration killed the escs. For the second time, I forgot to replace the zip tie holding the esc down. As a result, it became dislodged from the case & probably sustained some damage while the buggy jumped & jumped & tumbled & did all the rough stuff.
I will be sending in the damaged esc soon (I hope). In the meantime, how does one get a V3 ? I have only 2 more left & I have 3 vehicles... Regards, Joe Ling |
| All times are GMT -4. The time now is 04:47 PM. |
