-   -   Help with Batteries and chargers. (https://www.rc-monster.com/forum/showthread.php?t=154)
ryanvm777 02.20.2005 05:28 AM
yeah, but in the real world it dosnt always work that way
HotnCold 02.20.2005 07:27 AM
unless you live in your own little world - Im my little world my wife has no idea - LOL
crjackson 03.16.2005 08:32 PM
I really feel for you guys. Personally, I’m a male chauvinist pig, and I’m the one who must be obeyed.
RC-Monster Mike 03.16.2005 08:57 PM
That explains the avatar! :)
crjackson 03.16.2005 09:03 PM
Exactly, that and the fact I'm a retired policeman.
HotnCold 03.17.2005 06:35 AM
Even better a male chauvinist pig licensed to full time carry. LOL
rhylsadar 03.17.2005 10:30 AM
hi
i would not buy two chargers but rather one that can handle the needed number of cells. in your case 18 or above.
you should treat the two packs as if it was only one pack. charging them connected serial will give be the best way that the packs deliver the same capacity. if you haven't charged them togehter so far they should be formed up first. that is the 1/10 C procedure explained above.
that will make sure that the packs are as equal as possible. then you can charge them as if it was one big 18cell pack.
the delta peak cut off rate is lower for nimh cells than for nicd packs. that is why you can overcharge nimh cells using a nicd charger.
so be aware to buy a nimh charger or better one where you can set the cut off rate by yourself. (around 20mv per cell for nicd and around 10-15mv per cell for nimh are the numbers that are known te me).
as for chargers i could recommend one that can handle up to 25-30cells and charge with up to 5A. don't know what is commonly used in the us. (in europe that would be something like the intelli V3, gm vis commander or schulze d330)
the powersupply unit should at least deliver 10A.
bye
rhylsadar
