i was wondering what charger you use cus i ideally want a charger that can charge two packs at a time.
Hyperion duo
awesome thanks:mdr:
its interesting you had a similar experience. we have erevo and 3905 emaxx - both with
MMM 2200 set up. run the erevo with 6S and Emaxx at 4S. My son beats me or is close most of the time. What i discovered is that the stock erevo suspension setup out of the box is just not good for racing where the emaxx seems to turn much tighter as we run on a tight track. After spending a lot of time on the springs, shock fluids and getting it to turn tighter - single servo, removing steering stop i finally have a truck that will win if i dont crash... the funny thing is just looking at the two suspensions you would think the erevo would smoke the emaxx every time - it might on long wide tracks where the all out speed of the erevo comes into play but on short tracks it doesnt do the job. |
Looks like the EVX2 got a bug fixed.
The red middle wire from the receiver has a SS36 schottky diode on it. Looks like they are protecting from reverse voltage. I have been bitten by the press the button to turn "off" and everything goes in smoke problem and seems like this "solves" it because they no longer include the "turn off by removing the batteries" sticker.... yay Just FYI. |
| All times are GMT -4. The time now is 08:40 PM. |
