-   -   Anybody having MMMv3 Switch Problems? (https://www.rc-monster.com/forum/showthread.php?t=20024)
George16 04.08.2009 06:54 AM
Originally Posted by its me (Post 277499)
will cutting of the switch void a warranty claim?!?!? One of my v1 just stopped working no smoke nothing, thinking it might be the switch.. Is there another way to figure this out with out cutting it off?
I was told it does not void the warranty as long as I didn't open it up. I cut the wire about 1 inch from the case.
brushlessboy16 04.08.2009 07:05 AM
Originally Posted by Foxracin (Post 277410)
I sent Castle a email asking if extending the wires for the switch to put it in the stock location on a Losi 8 would void the warranty or anything and they said you can do anything with the switch or any of the wires as long as you dont solder directly to the circuit board. Soldering to the circuit board will void warranty.
:intello:
its me 04.08.2009 01:04 PM
Originally Posted by brushlessboy16 (Post 277505)
:intello:
thank you both ; )
e-mikey 04.10.2009 11:03 AM
Dave you know how many castle ESC's I've tried. EVERY SINGLE ONE had a failed switch. I've sent them back several with cut switches, no worries.
mistercrash 04.10.2009 11:23 AM
I like using a switch so in order to use the stock one as long as possible, this is what I did. Up to now, it has been good. If it ever starts to act funny on me I will replace with a better switch like Brian has. But it just keeps on working fine the way it is now.
First I wrap it to keep the dust out.
http://i177.photobucket.com/albums/w...th_switch1.jpg http://i177.photobucket.com/albums/w...th_switch2.jpg http://i177.photobucket.com/albums/w...th_switch3.jpg
Then I made this thing out of a piece of scrap Lexan to keep the switch from getting to the OFF position by itself.. A trick from Joel ''Magic'' Johnson back in the 90s.
http://i177.photobucket.com/albums/w...th_switch4.jpg http://i177.photobucket.com/albums/w...th_switch5.jpg http://i177.photobucket.com/albums/w...th_switch6.jpg
e-mikey 04.10.2009 01:49 PM
Nice, an Italian switch.
