Wow, I figured the MMM had 8s in it but 10s is nuts. I can't imagine it lasting too long, but props for trying!
I dought you could check the TVS even though its a diode which in general is easy to test, finding out which one of the surface mount parts is the might be a little bit hard, besides your still able to run it so leave it alone.
Not sure exactly where it is on a V2 or V3, but it's a fairly large device about the size of one of the FETs. On a V1 (at least on mine) it was located right where the power wires were soldered to the board (underside).
I agree though, that high of a voltage probably blew it very quick. It is designed to supress voltage spikes for a very short duration (such as when braking), but applying a constant voltage likely popped it within a couple of milli-seconds. All this means is that any protection from braking spikes is not there anymore. |
I better not brake then. :smile: here's a pic of the underside of the MMM board.
http://i177.photobucket.com/albums/w...vo/th_mmm3.jpg |
| All times are GMT -4. The time now is 07:20 AM. |
