tires are 4.1"
thanks for the help folks bed time see ya maniana
Ok, so far I have the following info:
MM Medusa 36/60 3100kv 3s 3200 lipo 4.1" tall tires Stock crt.5 diffs and spur Unknown gearing But with some sort of novak hv motor on 3s lipo and 13/46 gearing it was geared appropriately for the track. Can you fill me in on the kv of the novak motor, or at least the wind count? a 13t pinion on 3s looks pretty good to me for what you are doing: Differential Ratio: 3.25 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 46 Pinion Tooth Count: 13 Total Voltage: 11.1 Motor KV: 3100 Tire Diameter (inches): 4.1 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor coil Ω: 0.004 Spur/Pinion Ratio: 3.54 : 1 Total Ratio: 11.5 : 1 Tire Circumference (inches): 12.88 inches (327.17 mm) Total Motor Speed: 34410 RPM Vehicle Speed: 36.5 mph (58.63 km/h) Effective KV Value: 3100 I would definitely install an external bec, that will help with the esc temps on 3s. |
| All times are GMT -4. The time now is 09:11 AM. |
