Nice Virusss
Could you give us some more details on: the motor mount clutch you are using brake setup, mech, or are you using the motor to break total weight of the car |
Motor mount is made by Serum :) Super nice work
I use the brake stock system (mechanical), with the motor brake the esc make too hot, stop a 11 kg of car is difficult for esc. i don't use a clutch the pinion is connected directly to the motor shaft |
Very interesting browsing your eagletree file. I made a quick sum up graph while zooming into 1 minute of your run (mostly speed runs):
http://www.braintrust.at/2007/ds/rc/neu221510slast.gif Virusss, do you know your overall gearing? Which pinion size do you run? Judging from rpm and voltage level i suppose you run a Neu 2215 2.5Y (600kv), is this correct? With 5000mAh and a more constant / agressive power use (especially when running higher output batteries) i would expect runtimes to drop below 10 minutes (more then 500mAh per minute) and an average power of 1KW. You might want to get higher capacity batteries. |
Wow Othello, very nice explain my eagle tree file...
yes the neu is 2215 600 kv the gearing is 17/57 (stock) my runtime approx 18 minute if i remember correct i like to try 35c hyperion, and i like to try in offroad p.s. i like so much your video with eagletree file in overlay...how did you make? |
I am using a hyperion G3 3s 2200mAh vz 35C lipo and it performs great in a 1:16 buggy. Built quality seems top. Recharging with 10A (max 5c) takes about 20 minutes. Capacity although is only 2050mAh and not 2200mAh.
I posted some guidelines on how to insert eagletree data into a video about one year ago. This is my latest video with eagletree inserts featuring my custom 4wd Baja based on 2 1:8 truggy chassis. |
very nice guide for video editing :)
next week i try the baja off-road and i make a vid |
Hallo boys, i have a problem...
I must protect my 2215 from dust, but I do not know how close the fan that sucks air ... I had thought of putting a filter but I do not know what Any ideas?? |
You might want to try something like this
http://sites.google.com/site/planbpa...Luftfilter.jpg Stockings/nylons from your girlfriend/mam should do. And if you want to protect your front bearing from wet cut a round piece of felt, grease it, drill a smal hole trough it and glue/attach it on the front shield right in front of the bearing. |
yes othello, i like the collant system :) but in the rear side?
The baja in off road
http://www.youtube.com/watch?v=XmfC6aVQfmc and this is the savage converted to baja, of my friend Gyn77 http://www.youtube.com/watch?v=VpGcThkc1d8 |
Is it me or does those Bajas move faster then the gas version.
The first one was absolutely silent. But I would like some more details on the second one.
OMG that is sick....okay I have new focus. :yes:
Here the thread of my homemade Baja from a Savage http://www.rc-monster.com/forum/showthread.php?t=23285 |
| All times are GMT -4. The time now is 03:53 PM. |
