-   -   ERBE Motor Plate Brace (https://www.rc-monster.com/forum/showthread.php?t=23051)
mistercrash 08.23.2009 11:42 PM
Doing this will help in stiffening the motor plate by securing the bottom of the motor mount with a screw in the round plastic part the mount pivots on. When adjusting the gear mesh, that bottom screw needs to be loosened same as the top one. I have modified that round plastic part further more by installing brass inserts so that I can now really screw the motor mount very tight against the motor plate.
http://i177.photobucket.com/albums/w.../th_pivot1.jpg http://i177.photobucket.com/albums/w.../th_pivot2.jpg http://i177.photobucket.com/albums/w.../th_pivot3.jpg
Wild YFZ 450 08.24.2009 12:43 AM
Why not just make a mount out of a piece of CF.. Shouldn't be to hard with a dremel.
brian015 08.24.2009 06:57 AM
Yes - "Two are better than one" - screws in this case. When I saw the mount separating from the plate, I wasn't surprised since the stock set-up only has one screw holding them together. What you did looks nice.
mistercrash 08.24.2009 09:21 AM
I did and I know of one more person who did. CF is stiffer than the original alu plate but it still flexes too much under hard landings. And CF doesn't dissipate heat, my motor runs 10 degrees hotter with a CF motor plate.
