OK guys it's been over a week and still no response from anyone at castle, they must not love us anymore
i know, what a time to move one little buisness............how much longer can it take, i have rc's i need to break:whip: |
Sorry guys, I'm in the middle of a couple of designs right now- - I'll give this some thought when I have a chance.
Thanx! |
Hopefully, one of those designs is the final design for the 12S car ESC! :yipi::party:
If you'd ever like to discuss whats in my head and how you could implement it you know how to find me... Thanks
Thanks Patrick for dropping the line. We know you have plenty on your plate as it is.
I had a thought on this for Patrick. Maybe to better understand you could check out a local comp with all the free time you have. :yes: :whistle:
Seriously though, I think it would give you a much better perspective on the market and why something like this is needed. Just get a dump truck full of rocks dropped off at the new plant and buy some crawlers and check it out. |
Or login to rccrawler.com
A separate board that would: link two Mamba Pros together, combining the BEC outputs (doubling the BEC) and acting as a throttle mixer for the two MMPs... We already have the software for RX channel mixing available (we wrote it a few years ago for the Berg receivers) so it would require hardware and just a little bit of development. This would be much simpler than designing a double ESC. |
Feel free to give me a call to discuss but not sure that this will differentiate that much from the Novak dig unit - I use one and it works quite well but can glitch when switching modes sometimes.
I'm not sure its worth your development time to do just this...For $20 the novak unit it does what it needs to do... However if you wanted to try this as a beta of creating a combined ESC that could work - i.e. I could try de-casing a couple of MMP's, a bec and this unit into a single package - That would be good and then look at simplifiying packaging if it works well... Sorry but the internal bec's just don;t seem to cut it in crawler use - It might get better if two were linked but the CCBEC works best with the voltage adjustability and high amp support... Rgds |
agreed a single package is the important part, there are already afew company's that make units that let you use 2 esc with dig and so forth but alot of us dont have room for 1 mmp much 2 and an accessory board keep in mind alot of people use the mamba 25 as an esc, we dont pull alot of amps and normally get 45min run time on just 1600mah one thing that would be great would be if the esc could handle 4 cell, im sure novaks will only support 2 cell |
Space is another issue here. Two MMP's would take up too much real estate in an already strapped crawler. The thing is that the motor current in crawlers is relatively low compared to what people put monster trucks, buggies, and truggies through. I would have to believe that the BEC issue has to do with the fact that many people use the strongest servos they can and you get a lot of stall current (maybe incorrect term) when up against rocks and trying to turn.
Like Arct1k said maybe a jaunt over to www.rccrawler.com and ask for input would be helpful. Many over there already support CC so you wouldn't be going into the lion's den so to speak. Honestly you may could get away with a dual Micro Mamba setup with a shared brain. I really don't think the systems would require more peak amps than what it provides. Seeing as most people in the crawler world run 55t motors as the standard you can see what I mean. |
| All times are GMT -4. The time now is 09:41 AM. |
