I'm thinking about trying 50k in both diffs this time
i set up a thread just for diff oils to get a fixed answer... I put up a question up on each forum i am a member of, and never got a fixed answer...
Some like heavy oils and run 50/30 some like light oils 7/5 some like 20/10 or 20/30 But i never got a fixed answer... |
That's because its impossible to have a single answer. Its a function of the surface, your tires, your personal preferences, and your powertrain set up. Most bashers don't really give a crap, and just make a half assed attempt at "setup". And unless you bash in the same spot every time, your diff tuning will vary. I'd bet 95% of us would come up with different answers given the same conditions and vehicles.
My 2cents
In my bashers I always used a heavier wt oil. When I rebuilt my XXL diffs last time I decided to go with 15K F&R rather than my normal 30K-F and 50K-R. I had them this week apart just to check after 2 dozen runs w/6s and the gears look great yet. I think with the heavier oils it was creating to much stress on the gear train, with the lighter oil a wheel will break loose much easier and reduces stress ??
With the torque 6S puts out on the strain on the drivetrain, yes, its logicall to assume that a thicker oil will put an even higher strain on components as it has to work against that extra viscosity and friction.
i'm a basher and have the 5t conversion from tcs on mine. i used 30/30k at a suggestion of a fellow member and it seems to be doing fine. it seems to be harder to turn, but i'm also still using stock servo, so maybe its just weak with so much weight (7.5inch tires from cen nemesis too)
back to original thread question though, my first upgrade would be the radio if you don' thave 2.4 ghz, then probably the tvps. i still have the stock non bulletproof dif's in mine and even with the weight of the conversion and huge tires they are holding up just fine. when i filled my diffs about a month ago they aren't even showing signs of use. i have broken 3 stock A arms 2 tops 1 bottom both on front, but that was some serious abuse. i'm not sure rpm could have held up to what i did, the stock arms seem very strong. but rpm a arms wouldn't be a bad investment, they are guaranteed for life after all. |
What is the shock tube mod? |
Use the optional tube that comes with the kit above the big spring, and take away the little spring
This should mostly be a ride height adjustment. If you want to change the stiffness of the spring, go to a heavier one.
I bought my savage used and it came with nothing other than the truck and electronics. What do I need to buy to make the suspension work better?
The extra spacer doesn't fill a gap between the spring and the end of the shocks as the tube will have filled virtually all of that. It should actually precompress the spring a little adjusting both ride height and stiffness. There is a fairly big diff between the stock pink springs and the white springs so if you want a stiffness in between the spacers are the only way to get it.
The stock short spring actually seems to be slightly less stiff than the pink spring. You can see this if you hold them end to end and try to compress. So there is some small amount of dual rate happening. What i'm not keen on is the plastic collar that joins them. It rubs a lot on the shock body when things get dirty. What would be nice is a single dual rate spring not two separate springs. I used to run Raven dual rate springs when i had the LST shocks on and they were worked quite well. |
| All times are GMT -4. The time now is 09:31 AM. |
