-   -   Has anyone succesfully re-attached magnet/rotor to shaft (https://www.rc-monster.com/forum/showthread.php?t=31475)
bdebde 10.30.2012 07:09 PM
The green stuff I used set VERY fast! I was thinking of some sort of stop if I try again. Good luck and let us know how it goes.
_paralyzed_ 10.30.2012 09:01 PM
Originally Posted by Kcaz25 (Post 424328)
I will be going one of these routes shortly. The Green goo or JBweld. I am wondering how to get the rotor in the right position. I will be hard to measure the position while it is about to set! Can I devise some sort of stop? I want the rotor to be in the right spot of the shaft when it sets.
-Zack
use a pinion
Kcaz25 11.01.2012 07:17 PM
I think I just nailed it!! I was so anxious to do it right! I ended up cleaning everything off the shaft! Including the copper strip. I mounted it back though of course and with that same green lock! I had to clean out that slot that the copper strip inserted into first. I did this with the point of a razor blade I then laid the razor blade flat to scrape out the old green glue in the two big slots. I covered those locations in green lock already have my pinion stop ready I grabbed the rotor and very quickly slid into until it stopped necessarily at my pinion stop. I had to make sure the strip went into the grove on the inside of the rotor aswell! done! I will test it tomorrow!
http://i420.photobucket.com/albums/p...a/IMAG0506.jpg the finished picture would be boring. You've seen a healthy rotor
bdebde 11.02.2012 02:10 AM
Nice!
Kcaz25 11.02.2012 08:27 PM
Yep it worked! Tested it today with some full throttle starts
Recommend! Thanks guys!
