FLM bulkess with ue 8 spiders would be nice. and some UE CVD's stay away from rdlogic shafts.. Mips are okay too.
Well, to go on.. is this your budget for the entire car with electronics, charger and lipo's? |
It has the stronger magnet I ever had. Ciao, Daniele |
In my own opinion with drivetrain, I've started to buy the best or don't buy it at all. The top stuff is almost indestructable to what most people run. |
I also have the external BEC, it's a medusaproducts potencia and it works fine. I also have a pletty shadow to sell about 140 euros. So the budget is for everything but controller, BEC, charger ... IF I sell the motor and the controller I have about 1500 euros for everything but lipos and bec. But I also have to consider the f*****g italian douane. They probably will charge me 20% of VAT. Ciao, Daniele |
Any 4-pole motor will have the same story. Plettenberg is a torque-king motor in its size. And with right controller it starts much easier then 2-pole, because it stops always in between poles, not in random position. With desing you can minimize pole-pulling-holding effect (braking) but only with outrunners you can eliminate it completely. Plettenberg is a very nice motor, but doesn't have as broad RPM range, with high efficiency) as Lehner or BK 2-pole motors. But it does have a torque which most motors do not have, and 4-pole design mean twice more torque with comparison to the same wind 2-pole motor. So if you have a tranny which expand this range then it might be not that bad. And ones it spins all the pole pulling-pushing is under control and doesn't affect anything. Plettenberg at starluckrc cost around $210-235 Artur P.S. Rene are you sure Wanderer is smoother then Plet? |
And what do you think about outrunners ?
I have a Cyclon car 5000 and it's a really good and powerful motor for 1/10. There are some models also more powerful for trucks. Outrunners seems to me to be really plenty of torque. Ciao, Daniele |
So let's try with 1200 euros without lipos chargers balancers and bec.
Thanks a lot Serum for your help. Daniele |
griffin;
4 poles normally don't have got this huge resistance, so i don't need to be too carefull. and yes, i am very sure. I had them both, remember?? like i said, the bigmaxx had this nasty startup in compare to the 2pole feigao. the torque of the bigmaxximum isn't all that buddy! there was this calculation on here somewhere that showed a 8XL had both more torque AND was more efficient. and besides, i tried all differenent gearings with my bigmaxx and i wasn't that impressed. so i don't really know what torque this monster should have shown. Like i said, i tried all different things |
I run a 1950 8t and love it. I run it on 6s lipo now. I ran it before from 14 to 20 cells nimh. I don't have a fan on it and it is great. To my understanding serum the mgm can run a 2 to 20 pole motor from the sheet in them. I don't know how the pletty will work with them.
Yeah leroy, i know. but i never read anyone who actually used the maxxmimum or bigmaxximum on another controller than the schulzes. they are hard in the startup, as i described earlier.
For example, this is really a dream, but I think my budget is too low
for it: http://homepage.ntlworld.com/ryan.coombes/emaxx.htm I'm just going to emaxx due to the 1/8 diffs, otherwise I wolud have considered the Revo as well. Ciao, Daniele |
Ah, yes, Ryan's truck. Ryan is a great guy. I pm-ed you.
I remember Ryan considered changing motors ages ago. I don't think he did though. He was considering using 22mA cells too, as Lipos weren't really about and he wanted to lose some weight.
But my plett matted to MGM ESC and it is a sweet combo. And, yes we did compare plett with XL motors and there I said that it is not fair to compare them size wise. I do not want to go into details, just want to bring some good points about plett. Which standard 4-pole motor you have in mind? Not the ones with skewed armature I hope :) So far my complain on Plettenberg motor is that it is too hard on pinions and spur gears. But thats true for any high-torque application with poor gear mesh. Artur |
| All times are GMT -4. The time now is 03:12 AM. |
