-   -   E-Maxx Help (https://www.rc-monster.com/forum/showthread.php?t=3416)
GT4X 06.25.2006 06:14 PM
Thanks for all the help guys, I decided to go with either of these brushless setups:-
Feigao/Nemesis/Wanderer 8XL Motor
Warrior 9920 ESC
or
Lehner Basic XL 2000 Brushless Motor
Warrior 9920 ESC
Please let me know your thoughts.
squeeforever 06.25.2006 06:18 PM
Certainly the 8XL.
coolhandcountry 06.25.2006 07:30 PM
I would go xl wanderer. The xl2000 may heat up on you.
BrianG 06.25.2006 07:51 PM
Depending on gearing and vehicle weight, the 8XL can draw quite a bit of current. IMO, I'd go with the BK 12020 for a little extra current headroom. The 9920 should work fine though.
jhautz 06.25.2006 08:22 PM
I agree w/ Brian... 9920 will struggle with heat under racing conditions. Id go with the 12020 or the Quark 125. Biggest mistake you cna make when setting up a new system is to try to ''get away'' with an esc thats just good enough.
crazyjr 06.25.2006 09:02 PM
when you go back to the stock bumper mounts use the stock body mounts as well for the same reasons
neweuser 06.26.2006 02:47 PM
12020/8xl would be nice for what you are lookin for. IMO, dump the stock chassis too. Again, i have an FLM that you might be interested in. You can also use HB Pro's for diffs...little cheaper than UE and work great Squee said once i believe...
squeeforever 06.26.2006 03:12 PM
Yes, they are great diffs, however, don't get the Pro versions. They have a lower gear ratio for truggy's. The starndard are the same as a standard buggy diff.
neweuser 06.26.2006 03:18 PM
I see, sorry. I thought you had something about that, thanks for clarifying!
squeeforever 06.26.2006 03:25 PM
No problem. I do however have the Pro's. Maybe that's what you were thinking of? The Pro's are in my Lightning Stadium Pro-R though :p.
