-   -   warrior 9920 not working (https://www.rc-monster.com/forum/showthread.php?t=3578)
neweuser 07.27.2006 03:00 PM
Have you checked for shorts in your servo's? But honestly, I would send the controller to Mike and see what he says. Sounds like something is wrong with it...Try checking the connection to the motor, if you are not hearing beeps(and it's the motor that should beep), maybe bad connection there? How do you have it wired? Got pics?
aicecoldone 07.28.2006 07:12 PM
it works the stock reciever is toast took my reciever from my other car and it works.
4wdcanoe 08.16.2006 01:41 PM
from warrior manual:..
In case of no ‘beep’ either the gas travel is not long enough ( <0.128ms) or gas trigger (or stick) has
been moved to the wrong direction. Disconnect battery pack and receiver power. Lengthen gas travel
or invert gas, reconnect and start at 4.
assumed receiver gives steering servo okay info.. I would test with controller steering channel that the 0.128ms reguirement comes because steerin can often be fixed as "wider steer"
neweuser 08.18.2006 09:05 AM
Sounds great! Good job!
BrianG 08.19.2006 12:52 AM
The neutral setting for both steering and throttle (assuming 50/50 throttle control) is at 1.5ms. Min is 1ms, max is 2ms. That gives 0.5ms travel each way. The only ways a working throttle channel would give less than 0.5ms travel is if you were using a Traxxas TQ radio on 70/30, if the throttle trim was off, or if the signal was reversed.
I didn't read the full thread to see what Radio you are using, but if it's the TQ radio, set the throttle to 50/50, trims to neutral, and then switch the servo reversing control the other way.
Failing that; since the steering was working on your "bad" receiver, I would hook the steering output to the ESC and try it. And/or hook the throttle output of the receiver to the steering and try it.
aicecoldone 08.19.2006 02:26 AM
i did all that its just shot the stock receiver i am gonna just get a different radio set up
