oK Squee gotcha:013:
Thanks for the info guys will order the quark monster pro , the ib4200 7cell and the 9xl getting them now
If you get the Quark, get some heat sinks for it...and maybe a fan
Kinda didnt want to add the fan but dont mind the heat sinks does mike sell them maybe i should go for the neu 1515 1.5y
The neu will definately run cooler and is more efficient. If you run the Quark....i would suggest a fan! I run two 30 mm, works great, never thermal. heat sinks you can find at computer stores and such. I created my own out of a block of aluminum. Mike can make them too, shoot him a PM. Search around on line to see what is close and cut it, then use arctic silver to mount the heatsink, once you have it to where you want it, you can thermal adhesive it, but i wouldn't recommend doing that until you are totally set after test runs as you won't be able to get the heatsink off!
OK here it goes quark monster pro,Neu 1515 1.5 , ib 4200 , and the ubec , NOW you know i will be asking questions after recieving items
run your cells in series...zoooom...zooom :)
Wise choice about the motor.. :)
So eager to purchase the motor didnt notice it says sorry this :010: motor is not in stock ok back to the drawing board any suggestions:032: :031:
OK check this out how about I get the monster pro, in the meantime use my hacker c50 and then instead get the G3 but i think there might be more stuff to buy like the motor stand :032: :007:
The 1512 2.5d is a good motor. It runs pretty good on a monster truck. I run mine on a 80b quark. I would suggest a 125 though.
would a difference in 700kv be substantial or is it just preference
I understand the i should get a lower kv motor for the torque because of the amount of weight
You want to match the kv rating to the voltage you are planning to run. Shoot for a total rpm in the neighborhood of 35,000 - 40,000rpm.
So... the 2700kv motor would be a good 12 cell (or 4s lipo) motor, 12(cells) x 1.2(V/cell) x 2700(kv rating) =38,880rpm. the 2200kv motor would be a good 14-16 cell (or 4-5s lipo) motor the 1700kv would be good for 16+ cell (or 5-6s lipo) motor. Geared properly, there shouldn't be much differance in top speed, but there will be in tourque. Since it sounds like you are going for a 14 cell setup, I would think that the 2200kv motor would be ideal, and it would even leave a little room to add a cell or 2 in the future if you wanted. |
I have the 1515 2.5D (1700kv) I think it's a nice motor too. I as going to get the 2200kv one but they were out of stock. I like them in the 2000kv range... but depends on the vehicle and purpose. If I was doing a speed/bashing truck I would choose the 2200kv if not the 2700... |
| All times are GMT -4. The time now is 05:10 AM. |
