Single setup is much better IMO..... Havin' dual sounds cool, but you never know when/if the two motors/esc are fighting eachother.....
They are rotating into the same direction, so it's most likely they work together. It doesn't need an accurate timing when you use two motors and two controllers. It takes more care to use two motors on a single controller.
If you are using 1 esc and two motors, you need the rotors start at an identical time. The esc needs to see the two as one motor only.
For as long as you run both combos on the same battery, you should be fine. (use two Lipo packs in parallel)
Makes sense. Thanks
| All times are GMT -4. The time now is 06:25 AM. |
