So, I'm safe running a 6 cell reciever pack into the reciever and my 4s pack into the ESC once I turn off the internal BEC on the ESC?
crazyjr: That post was too confusing for me to follow, lol.
fiero: Yes, that is fine. But of course, you'll reduce weight by using a UBEC on the 4s pack instead of the 6 cell receiver pack... |
How do I turn off the internal BEC on the mamba ESC, I don't see a setting in the castlelink software........ Do I just disconnect the red wire on the lead that goes from the ESC to the reciever? |
Yup, just disconnect the red wire...
Awsome... gonna be driving this think in like 5 minutes! super excited :):):)
Ok... somthing whack going on here...... I connect the lipo battery and I'm met with fairly large sized sparks from the connecter and the ESC wires heat up rather quickly :(
This thing worked fine on 3s last week so the ESC shouldn't be toast......... Edit... I'm a F$%^ING idiot! polarity is backwards... god dammit! :p Which battery should I connect first, ESC @ 14.8v or the reciever? |
Woo hoo! It's alive!
Driving time :) |
Well, anytime work load is taken off the ESC, it can handle more of some other load (no BEC, handle more voltage).
However, I beleive the MM is robust enough as to where it can run just about any 540 or smaller BL motor at 3S so long as the KV is in a resonable range (motor RPM ends up being the "standard" 40,000). 3S is equal to about 9 or 10 cells, so I wouldn't be using the BEC on anything about 3S/10 cell. |
| All times are GMT -4. The time now is 05:52 PM. |
