no i think he assumed that with the hv setup you have more power so you can gear higher. so the car will be faster.
Yes alot faster. Even with similar gearing you might just be real shocked. Calculate till you're blue in the face. It'll be faster on the low kv/high voltage even though the R/C calculator doesn't really reflect that. I just have a Basic 1200XL motor and even on 4 cell it's real snappy in a pede. 1200xl on 6s will be more then enough to push the pede to it's physical limitations. 8s would be good fun to watch LOL. Be careful with that trigger or you might be scraping the trany up off the road.
well the plan is to start with 5 or 6s and work up. but it can't be much higher than the KV says, I know there will be more losses with a lower power high kv setup,But will the difference be that much?
| All times are GMT -4. The time now is 02:55 PM. |
