-   -   Dual 5700 Kv Mamba Maxx (https://www.rc-monster.com/forum/showthread.php?t=7044)
ssspconcepts 06.27.2007 11:10 PM
New paint for my dual maxx
3 Attachment(s)
Well I received my dual flightpower 3S 5000mah lipos (to be wired in parallel to dual mambas 5700kv in parallel) and new MRC 989 charger. Getting closer to finding out what dual bl can do. Hopefully I will have some result to report this weekend. BTW, here are some pics of my new paint...FranksBodies did the paint....I can't take credit for his art.
snellemin 06.27.2007 11:46 PM
That's a really sweet paintjob!!
JOHNNYMAXXIMA 06.28.2007 02:13 AM
Looks great SSS! Let us know know how it runs as soon as you can. Are you going to swap tires for your speed runs? Those puppy's look like they will baloon pretty good.
offroader 09.22.2007 11:59 PM
I've been testing a Mamba Maxx with 5700BL motor with 3S lipo the MM esc gets too hot and shut down after about 5 mins Temps get around 125F. Is the setup under sized for a Emaxx or would a cooling fan on the MM esc help from shutting down? Motor runs cooler about 85F but I have a cooling fan with heat sink on it. Also I use the Ubec from the MM would it better to have a seperate Ubec?
jnev 09.23.2007 12:35 AM
That set up is WAY to small for an e-maxx. The ESC would work, but I am not surprised the motor is getting so hot. It is designed for a light 1/10 scale 2wd buggy or truck.'
Getting an external BEC will definitely help.
_paralyzed_ 09.24.2007 09:53 PM
pics don't work for me, I wanna see!
Arct1k 09.24.2007 09:59 PM
http://picasaweb.google.com/ssspconcepts
use this
offroader 09.24.2007 10:44 PM
Boy, this is sweeet! Man you did a good job on this. What do you think this will cost at the end?
ssspconcepts 09.25.2007 05:59 PM
Hey all,
Thanks for your continued interest and for keeping this thread alive.
I have been really busy with a new assignment at work and my time on the forum and with RC Monster Trucks has been limited. I essentially built two very similar trucks...one with a 4.5 Novak (with combo bulks & 1/10 hardened gears) and the other a Dual 5700kv Mamba (with hybrid bulks & 1/8 hardened gears).
About two weeks ago I took the Novak truck out for one serious bashing session in order to push it to its limit...the 1/10 diffs failed. Since then I have done an extensive rebuild and have replaced the diffs with UE spider 8 gears. I also replaced the two-speed tranny for a G-Maxx single speed tranny with metal gears. I have also ordered a Neu Motor and will be replacing the Novak 4.5 system with a Neu/Quark 125 combo...all to be powered by 5S lipo.
I want to compare the two trucks and see which performs better. It won't be long now.
Sombody asked price...yikes! I HAVEN'T KEPT TRACK, BUT I'D SAY IT IS SAFE TO SAY THAT EACH TRUCK IS WELL OVER $2k (not including radio gear).
ssspconcepts 09.25.2007 06:06 PM
Temps
BTW. Somebody asked if the dual Mamba system gets hot....yes it does. However it doesn't get any hotter than my single 5700kv Mamba powered 1/10 stadium truck used to on 3S.
The dual system runs dual 5700KV Mambas in parallel and dual 3S FP lipos in parallel. Power and speed is incredible.
