-   -   Possible Kontronic HV purchase... (https://www.rc-monster.com/forum/showthread.php?t=7863)
lydiasdad 09.26.2007 04:16 PM
What about this monster? http://www2.towerhobbies.com/cgi-bin...&P=SM&I=LXSDV4 It ha scar software also?
lutach 09.26.2007 04:51 PM
The Power Jazz 63V doesn't have car software. I tried asking Mike at Kontronik if he can add the car software to it and he said it would take 4-6 weeks, but I haven't heard anything yet from him.
nl12 09.26.2007 08:27 PM
I would like to get a Power Jazz 63V, tell him you know another person interested in getting one, maybe it will speed them up. PM me if you hear from them
Thanks
othello 09.26.2007 08:36 PM
@lincpimp
with "car" extension i meant those ESC which have "car" at the end of their labelling -> Jazz 70 "car".
The Fun 600 motors are somewhere between a feigao L can and lehner/Neu. We already discussed the Fun 600 motor in this thread.
@Serum
I posted a picture of the rotor (from kontroniks website) on the above mentioned thread. Maybe you can tell from the picture if they are sintered or sliced. They for sure are not as segmented as lehner rotors and don't look sliced to me.
Before using a neu 1521 with 10s1p A123, i tried a fun 600/11 (1100kv) which only survived 4 runs (it was preowned so maybe it already had some kind of issue). Right in the middle of my last run with the fun 600/11, rpms rose dramatically and i couldn't start the car from a standstill without cogging. On my eagletree graphs i had Amp spikes of 70A (around 1800W). Before this event it never drew more than 40A. Temperature measured on the heatsink was at 65°C (149°F). So maybe i possibly demagnetised the rotor or a wind shorted because the seal overheated. I never expected this to happen (not at this temperature level). So what i learned from this lesson was: you have to properly cool those Fun 600 motors. The fun 600/11 would have needed a fan on top of the heatsink.
Those are the graphs from the last run of my fun 600/11
-> look at the last rpm spike at the end
http://bt2007.braintrust.at/ds/rc/fu...fahrprofil.gif
-> before i understood what has happened i tried to spool up the motor a few times: look at the amp draw (Watts), RPMS and motor temperature
http://bt2007.braintrust.at/ds/rc/fun600_11_exitus.gif
Don't get me wrong. I don't want to say those are bad motors. My fun 600/25 still runs great today, but it gets hot and needs good cooling. After a 10 minute run in my Ezilla i can't touch the motor longer than for 1 second although i use a 50x50 pc fan above it.
lutach 09.26.2007 08:56 PM
Thanks
He is not replying to my e-mails LOL. I even went to rcgroups to ask for it there.
lutach 09.26.2007 09:00 PM
Originally Posted by othello (Post 120082)
@lincpimp
@Serum
I ran the FUN600-15 with 10S A123 on my BPP truggy and it lasted a little longer than yours. They are good motors, but I think the Neu is the way to go. I had my first downfall with my old 1412 1y Aveox, but it is only the shaft that came unglued.
nl12 09.27.2007 08:24 AM
the Power Jazz 63V should work fine with mechanical brakes right?
lutach 09.27.2007 09:10 AM
Yes, it will work. It also works with a pistol radio.
AAngel 10.01.2007 03:58 AM
Yeah, that kontronik HV controller looks nice. I went and looked around hoping to find something about running it in a car, but no luck either.
If the controller is as bullet proof as they say, the price tag isn't high at all, considering what the half dozen MMs, two Quarks and four Compros cost looking for the "right" controller.
starscream 10.02.2007 03:38 AM
Is it difficult to get the Power Jazz to work properly with a Pistal radio.
I always run with mech brakes so forward only is fine for me and I may have to give this esc a try if progamming for a pistal is easy and dependable.
lutach 10.02.2007 07:20 AM
I heard from that the boat guys from rumrunnerracing.com, that it does work with pistol radio. Same with the Jeti/Hacker Spin controllers, they also work with a pistol radio.
Aragon 10.07.2007 01:48 PM
Originally Posted by othello (Post 120017)
Kontronik btw doesn't recommend Jazz ESC (without car extension) for car use.
Who said that? I've heard the opposite from Kontronik...
FWIW, I run a Jazz 40-6-18 on 4S in a 1:10 buggy. They work great, and the latest version 8 firmware has fixed one bug I used to experience, and improved the braking/reverse algorithm since version 7.
My BJ4WE has the Jazz setup right now. I was running it in my old RC10 when I posted some results of it. The beauty of the low voltage Jazzes is that they have a builtin switching BEC.
Well I've got a 1:8 conversion in the works, but haven't finished it yet. It's been months since I started it! Hopefully I'll get it finished soon so that I can post my experiences. I plan to run a Jazz 55-10-32 and a Neu 1912/1Y on 10S Lipo in it.
othello 10.07.2007 03:18 PM
Some guy in germany had troubles with a jazz 80-6-18 and Plettenberg Maxximum in a Emaxx. When going from full throttle to say half throttle the motor followed immediately his command: for him it was like braking. While jumping it was troublesome (now he uses a Schulze and does not experience the same behavior).
So he called kontroniks support and their answer was that he was the only one experiencing this behavior and ultimately he should have been using a Jazz car and that they do not recommend other Jazz controllers for car use.
That is the story behind it!!!
Your future 1:8 setup sounds interesting. The Jazz 55-10-32 is a powerfull ESC and is used in helis at up to 4KW (10s and 120A). The 1912 should run very cool. Don't forget to post pictures and comments on this setup. Sounds very promising. Good Luck with your future conversion.
Aragon 10.07.2007 03:34 PM
Thanks. I hope to finish the 1:8 soon now. Maybe in the next month. Will update my thread here when its done, but you can see some of it in my RCG blog entry here for the time being.
My brief conversation with Kontronik on my proposed setup seemed good. Can read it here.
othello 10.07.2007 04:58 PM
Judging from your thread you put a lot more effort in your conversion than i did:lol: Nice motor mount btw
I used a emaxx motor mount, dremeled it the way i needed it and bolted it to the front diff mount. My old buggy already had a plastic spur. I think i used the same material to make my battery trays and wrapped it with Gaffa tape for more stability.
Seeing 2 battery trays and the fact that you turned your center diff to the front i would assume you are going for the following setup
http://www.braintrust.at/2007/ds/rc/buggy_layout.jpg
right?
pretty much what i did too ...
This is a pic of my old 4s setup (Jazz 80-6-18, Fun 600/25 and Konion 4s4p)
And this is how i run it now (Jazz 55-10-32, Neu 1512/2y, 10s1p A123)
