Having more of a smaller uF cap will have the least resistance, much lower than one large cap.
Hi Zeropointbug. Did you get your Quark ESC fixed? |
You can't measure ESR with an ohmmeter. A meter outputs a small voltage and either measures current flow or measures the v drop on an internal resistor, and then calculates the resistance. If you put a meter on it, you'll see the resistance start very low and then rise until infinity.
This resistance, which should be called ESR for this discussion, can not be confused with Xc, which is capacitive reactance. Xc is a "resistance" as well, but the current is 90* out of phase with the voltage and the Xc "resistance" value changes with frequency (hence "reactance"). ESR is not Xc, but sorta like the 0* phase DC resistance. Quote:
Precisely! :wink: sikeston34m.... nomods sent me a burnt out Quark with what a appears to be a good brains board on it, but unfortunately, i popped it onto my Quark, but no luck, doesn't even turn on. I noticed it has two little tiny caps missing from the board near the motor phase sensor end (where you solder it). If anyone has a Quark they are willing to part with (that has overheated, or w/e) and knows the brain board is fine.... I am accepting them! :whistle::wink: |
Excellant Information Brian! Thank you. I have attempted to measure them before and noticed how they charge up under the meter.
I was hoping to catch you Zeropointbug. I need a favor from you. I am doing some research on the Quark line and what I need to know is this. I need to study the Gate Lead Driver circuits on the brain board of the Quark to figure it's amp carrying capacity. I do have an 80 amp Quark here, but this requires disassembly, and separation of the two boards to get the numbers from the driver fets. I'm not willing to take mine all apart, I'm using it. I looked at your pictures and they are not close up enough to get the numbers. Do you have any extreme closeups of the Quark Brain? Take a look at my thread on "Quark ESC Power Board Mods/Comparisons" to see why I need this. There may be some things there that interest you. |
Yeah, I just got my internet connection back from it being down for a week! :no:
Do you need the reverse AND top pics of the brain board? I do have pics of them close up, but I am not sure if you can see any numbers... I will get some pics for you as soon as possible! Anything else? :smile: |
I really need both sides of the brain board. Extreme closeups that will show the numbers on the components.
Some of the numbers are almost too small for me to see with my naked eye, but the camera has a way of really blowing it up. Welcome back ZPB. I thought you were probably vacationing. |
Okay, check out my pictures in my sig..... there will be 3 pics of the brain board at the end. :yes:
Great!
On the last picture, the 3 fets in a row are the gate driver fets. The top number looks like I1760. Is this correct? The top number is the model number and the only one I need. The others are date codes and such. |
| All times are GMT -4. The time now is 02:20 PM. |
