I'll go out on a limb and assume he meant 'windshield', which would mean cutting a hole in the windshield of the body for more air flow.
yeah i guess thats it ill cut my windshield l8r 2day to see
who needs a windshield anyway...
lol when i get my Crowd Pleazer 2.0 for my Maxx im nto gon cut the windshield
and its gonna have light buckets and lights! |
What in the *&%#@ is a WINDSCREAM?
Must be a English terms, but yes i am referring to the 'wind shield'..
i put a hole in the windshield and ran it and it didnt thermal
but i twisted my rear shafts so i have to get CVD set soon |
A little air works miracles every time..
I've been able to go with a 14 tooth pinion by using a body with out the window insert.
To help keep things cool; sometimes I use a can of compressed air to rapidly cool things down. If you turn the can upside down and the spray. The liquid gas rapidly cools that area and then evaporates. So you don't have to worry about the electronics.
Rapidly cool a hot motor for example down is a bad thing and can cause damage. If you want to cool it but still be safe, use a fan.
Sorry I should have been more clear. I don't take a motor so hot you could fry an egg on it and make it as cold as ice. Instead I constantly moniter it and spray a little here and there. I only do it on the outside. When you allow small delicate parts to go from extremes in hot and cold, things can break.
Doing this is a lot like having a heat sink. |
you must know that something that might feel hot and burning on your hands is only 117 degree fahrenheit. this is a 'no sweat' temp for electronics.
i personally would not use something to cool electronics of fast. This might cause a loose contact on the print where the transistors/fetts are soldered on.. |
| All times are GMT -4. The time now is 11:53 PM. |
