Which parts i need to fit LST shock on Savage???
http://www.innovative-rc.com/product...roducts_id=130 |
OK thank you, i've take a look at the innovative rc kit, it seam to be very well make.
But why they tell that this kit fit the Savage XSS but with the non-X arm:neutral: Which arm do i need to fit with this kit, and do i need front and rear arm?? upper and lower? And is the non-X arm is as good and solid than the X one?? Thank you! David |
Oupss! Just see this.
http://www.innovative-rc.com/product...roducts_id=113 Is this parts allow me to use the stock Savage XSS arms with the innovative rc LST shock conversion kit? |
I think form memory the X arm is lighter then the old style A arm needed for that kit. Here are the A arms http://www.smfstore.com/product_info...products_id=43. The difference between the X style and .21 .25 style arm is that the old style has shock mounting holes on both sides of the arm so the Arms can go on any corner of the truck. The X style arms have 2 different arms for different corners. The Kit uses the shock mounts on both sides of the old style arm to mount the shock. The upper arms are the same.
They also have these for mounting on X arms but I would think these would lower the ride height of the savage http://www.innovative-rc.com/product...roducts_id=113. They also require offset rims. |
| All times are GMT -4. The time now is 08:35 AM. |
