I commented on one of your other threads how your models are always sitting in a performance shop showroom floor. :lol: I’m a huge turbo junky too with several FI projects, mostly all Subaru related (on my 5th). My last project was a NA->FI swap, 2.5l boxer motor, 20G, 44mm EWG, FMIC, PPG tranny, and put down 410whp/380ftlbs. Not bad for a grocery getter. I’d like to see that TT supra run! |
Anyhow, back to the fun stuff...hehe. I tried fitting 4 lipo batts that I had laying around and 2 of the HV100 turnigy's I had extra. I don't think this is going to work..... So my question is what do you guys think would be the best way to go. Just run a single 1527on 12S or is their a different motor I should try?? I want 100mph out of this big buggy. I've seen 100mph+ RC's but they are all small, lightweight and don't look anything like an RC. Most of them use bodies that look like they came straight from wind tunnel testing and most are 4-5lbs max. That doesn't impress me, but I think small and light sure makes it alot easier to get these things to go fast. |
No - I was thinking what kind of turbo can you get in an Audi TT 3.2...
Linc - We all need someone :) |
2 Attachment(s)
I'm going to see if I can move some stuff around and fit the parts. If not it maybe just a single 1527.
man i'll give you my setup out of my yusa rally in a trade for a turbo set/install on my N/A crossfire. it metered around 6hp.
seriously though, i'm liking this buggy. i seen another one somewhere and i got excited and started searching ebay for a roller. couldn't find a deal so time went by and i forgot about it. |
The majority of your HP and torque will be at take-off and possible at the upper end of the speed range where drag is the greatest. Depending on how high you have to gear up, I would expect more current than 100A even on 12s considering the weight of your vehicle. Some of the lighter cars are pulling over 100A. How about using a Castle HV-110? They are actually underrated and should be more like a HV-130. And Castle may be willing to add an extra FET PCB to get it up to something like HV-170 level. Or, their hydro HV-240 would be possible if you replace the cooling tubes with actual heatsinks.
Also, while dual motors increase output significantly, the output probably won't be exactly double because of the slight parameter tolerances; one motor may be spinning slightly lower than the other and/or ESCs may not be outputting the exact same throttle level as the other. I would use one larger motor instead. Weight will be reduced and setup will be simplified. A 1527 1.5d or 1y (kv around 1300) on 12s should be plenty. Something else you want to look at is if you can get the gearing needed to reach that speed with the spur/pinion, tires, voltage, motor kv, etc you have. Since your vehicle will be so heavy, what about using a two speed? If using a single speed, the motor may have a hard time to pull that weight geared so tall (more of an issue with a single motor). The only thing I'm wondering is the tires breaking loose on shift. At the start of my project, a couple hi-speed "veterans" chimed in. While their vehicles were small and light, they said aerodynamics plays a VERY big role. The idea is the make the body as aerodynamic as possible (this includes covering turbulent areas like under the car, around suspension components, and around the tires), while providing adequate downforce (but not too much) to keep it planted. Hence, the funny looking body styles. I have a Porsche body I'll be using for playing around, but am planning to make a homemade lexan/plexi body similar to the typical "airplane" looking ones for the high speed runs. |
I will run the 1527 on the HV 110 then. I have it laying on the shelf since I was trying to cure my glitching problems. Apparently the Turnigy did a little better but still not good.
I really can't wait to see the performance of the 1527.... still waiting for the 40.300 by schulze as well.. Lutach.. does ur Jazz have reverse?..
The 1527's should start shipping by end of next week.....
When are the SHV controllers available?? Guess I should call them to find out.
Called and the SHV 110 and 160 are available already but through an exculsive dealer that does Jets. So I guess I need to find out who that is. They have the rights through end of June. They will handle 20S and you have to sign a death waiver......guess the volts and amps are getting serious..lol
JZ you're doing your runs at an airfield correct? If so, couldn't you slowly spin up to speed to compensate for the high current draw at start or would that not make a difference? Also if you used Fm crystal type tx/rx would it be possible to use 2 tx's (one tx at 1/3 point the other at 2/3 point) with 1 rx for extended range?
Yeah we are at an old airport. I could do the slow spoolup, but problem is my radio range sucks, and won't reach long enough to get the truck going slowly. I need more range.....big time.
Maybe that is the company that has them.....guess I will call.
If you have any more info.. hook it up... I'm in need to run 20S, just for the heck of it.
Castle should make an onboard data recorder for the SHV or Eagle Tree and BNB Products will have to come up with something.
Do you use spektrum? You could go for a high gain attenna on rx/tx to gain more range
Yeah I have a spektrum DX2.0, but I'm selling it. I need one that will handle more model memory. |
Just an update, but NO response yet from BVM on the SHV controllers that are now available. So Lutach if he answers you let me know....I have money in hand for a new contoller.
Hmm well let me know. Get the amp ratings for them if you can. CC told me if I ordered an SHV110 that I can have it custom made to be a 160 or 180 I believe. A SHV180 would be the bomb for sure....
2 Attachment(s)
Ive been away awhile and was looking around for info on the Mamba MMM esc and saw your post.
I have some advice for you I was going to do this about a year ago with the XLB but decided the cost of electronics was to high at the time and my RC18B was fast enough for me at 93mph on 4s curently working on a 5s setup along with a 3s scalpel for speed cars. Aero wise the buggy body is the best way to go it's a lot like an indy car with the buggy rear wing and adding a front wing it will allow you to control how much down force the car has and keep it on the ground at high speeds with the smallest frontal profile on the RC18 I tried a few full bodies and found they were all slower then the buggy body? Tires? I would highly recomened Jaco foams for the Tmaxx they are the largest foam tire and wheel avalable for MT's and should work great on the XLB dont waste your time with glued beads they fail around 60mph beadlock wheels are much better at holding the bead on at high speeds. Shocks? I found instead of using spacers under the pistons to lower the car using springs instead softens the top out of the shock and improves handling and stability at high speeds. Chassis flex? The XLB needs a lot of help in this area pick it up and twist the front and rear of the car in oposit direction's for high speed stabilty you need to eliminate this flex. Motor and ESC? Duel 15 series Neu's with MMM ESC'c on 6s should be enough torque to get you to a 100mph plus? Radio? check out the Worlds fastest RC thread for extending the range on your radio system. http://forums.radiocontrolzone.com/s...d.php?t=239623 Good luck I think a 100mph is very doable with the XLB. :) Quote:
The front wing is a nice idea. I did that on my buggy. You can find the picture of it here: http://www.rc-monster.com/forum/show...00&postcount=8
Yeah I am looking at something now. 100mph in a 1/7th scale, 15-18lbs and 17" wheelbase buggy is asking alot as it is.....lol. The little purpose built speed cars with aero built bodies and 1/4" off the ground is alot easier. I think this will turn out to be more difficult then I anticipated. I don't really know if the wing will hurt or help. Since the car is so large a large wing like that would create huge amounts of drag. If it were a small 1/12 or 1/10 scale touring car it probably would be less amplified. I think I am just going to remove all the wings, and attach a difuser under the flat pan chassis like a Formula 1 car and use the air underneath to help pull the car down at speed.
F1 cars use wings to keep it on the groung there is no ground effects used anymore in F1? the old cars used tunnels or ground effects under the car to create vacume to suck the car to the ground along with wings.
defusers are used to control turbulance under the car witch reduces drag used without wings or a high downforce body under acceleration and weight transfer the front of the car will lift and stack the air under the car inducing a flip? The scale of the car does not matter the same aero dynamic prinipals apply be it 1/18,1/7 or full scale the main difference is weight and the power or torque it takes to overcome the aero drag and weight diferences as the scale size increases. |
The principals are the same for all scales yes, but the drag is not. Smaller object takes alot less power to push through the air all things being equal. As the scale gets larger the frontal area increases, which can be independant of the weight. Also I don't plan to use any ground effects.... |
| All times are GMT -4. The time now is 06:19 AM. |
