I'm with azjc on this one.. I started out running a C4 9000kv motor that just seemed like small portable heater. Lutac, I'm sure your Mega ACn16/15/1 made a fair amount of heat no matter how efficient is. How long were you able to run it before it got too hot? I just bought a Neu 1115 1D (5700kv) that I'm going to try to stuff in another 1/16 project with a custom chasis. The thought is to run it on 3s and gear fairly high due to the expected torque output of such a long can motor. I will post some feedback here.
I'm running a 25T pinion from a MLST in my "Recoil". I use quotes because it's actually a Carisma Nissan Skyline R32 which is essentially the exact same car minus the body and wheels, which I favor over the Sportwerks offering. I currently have a Hyperion Y-22 6000kv short can motor in there. It is very quick and top speed is pretty good as well. If I were to go to a track, I'd probably use this setup as it is. It does get a little hot after a few minutes, but I think adding a fan over the motor and ESC should tame things long enough to enjoy for a real race.
My next motor will hopefully be the Medusa MR-028-032-4200V2 to run on 4s. I'm not a guy who only runs extremely high kv motors on 2s. It's good for bashing and maybe a long race so I can run 2s 2p, but that's not all I do.
| All times are GMT -4. The time now is 06:25 PM. |
