-   -   mmm + fiegao + Nue + muggy = hot hot hot (https://www.rc-monster.com/forum/showthread.php?t=14627)
Gooberseptember 08.30.2008 09:03 PM
Its a great charger. Simple to use. Pretty much the last charger you will ever need. If it has the latest firmware you can charge every battery on the market.
if it doesnt have the lasted firmware, shoot me a pm. I send ya the cable to update it as long as you promise to send it back to me. LOL LMK
lincpimp 08.30.2008 09:21 PM
Originally Posted by roweder (Post 207075)
with a monster like the muggy I think that you should consider at least a 6S pack for your next battery, but not a maxamps, lincpimp said he's had 12 different maxamps batteries and he's had to send them all back, he recommended for me to go with anything that uses enerland cells, I think you should too, he said that any flightpower, neuenergy, thunderpower, polyquest, or poly rc pack will be exceptional, they use enerland cells. This is the one i'm getting: http://www.amainhobbies.com/product_...ducts_id/17987
Yeah, the 6000 maxamps packs are just a 2p pack made out of the 3000ccells which are good for 40-45amps max, so the 6000 pack may do 80-90 amps... on a good day.
Really difficult to understand the difference, until you try similar packs on the same setup. My first enerland cell pack was a polyrc 3700 5s pack. I bought it used for 75 bucks. I gave it a try in my tekno converted revo. 2000kv 1512 sized aveox motor, and a quark 80b esc. Truck still has the 2 speed and mech brakes, so it is realively easy on the electronics. I used to run a maxamps 5000 5s pack. So I gave the polyy rc pack a try. Big difference, more puch and power, and it seemsed to give the same runtimes, plus it just seemed to hold higher voltage longer than the maxamps.
The polyrc pack is a 25 c pack, but only speced for 92amps cont. The maxamps is similar with a 100amp rating.
My main issue with maxamps is the cell quality is all over the place. I had a bad cell in all of my packs, and some were even delivered to me with the bad cell...
I have a bunch of enerland cell based packs now and none have let me down so far. I have some truerc packs too, and even after letting the cells get down to 2v they still took a charge and didi not seem to lose any capacity. Try that with a maxamps pack... or try to find a pack from maxamps competitively priced with true rc...
roweder 08.30.2008 09:58 PM
are you saying that if a new type of battery comes out that this can't charge, then I can install TP software and then plug the charger into my computer and after that it will be able to charge it?
Gooberseptember 08.30.2008 10:17 PM
pretty much!!!:party:
roweder 08.30.2008 10:21 PM
Awesome!
Edit: Now I know what you meant by +1^^^^^^^^^^^:lol:
roweder 08.31.2008 10:03 AM
it's 25 bucks for that cable, if the charger doesn't come with the latest stuff, then I would love to borrow it, I'll pm you if it doesn't.
Gooberseptember 08.31.2008 10:48 AM
Not a problem.
