Just PM me here, with all the info above.
You are going to need more than 5000 mah 25c batteries if a 1.5 turn hv motor is going to be any use at all. I would recommend at least two of those in parallel. My hv 4.5 already taxed my maxamps 5000 mah batteries and a I imagine a 1.5 turn would have the capability of drawing three or four times as much current even with only 2s, compared to a 4.5 turn on 4s.
If Bob or Steve have questions about the controller, I will have them contact you privately at this email addy. I have the order ready to go. |
Regards. |
Just replied to Bob Novak and now lets see if the 1.5T and 2.5T can be done so I can set the standard for 2S lipos speed. This will be very fun to do.
I think you missed a couple of my posts above: We will only wind a 2.5T HV Pro motor We will not wrap it with Kevlar/epoxy, but the magnetic material in the HV rotor is our highest temp magnet and it is the only rotor we (have) use in the HV motors. When do you plan to run this and where? |
Just use 2 of the 30c 5000 mah in parallel - you can take 300amps continuous!
Bob said that will do the kevlar wrap.
hmmm getting more interesting.
This is getting interesting for sure.
But we know where you live...
You're brazillian - I thought you guys liked that ;)
Well Okey, dokey then....
Lutach, you can just email Bob directly. My "conduits" are overloaded....:wink: |
Things will get interesting in a couple of weeks. You'll all see :diablo:.
What about putting a Novak 7.5 HV Pro ESC motor system the 5mm version on 3s lipo in a Slayer conversion?:diablo::whip::diablo::whip:
I'm very excited about this answer from Bob:
"The motors are done except for the rotors which were wound with Kevlar thread this morning. The glue has to dry for 24 hours so we will be testing them first thing tomorrow. I will let you know what the KV of each motor after we test them." I can't wait to have the motors here. |
After you toast them, can I have the cans????? :intello:
Neither should be any worse than a HV 4.5 on 5s.
Alright :yipi::yipi::yipi:. The motors are ready and they'll be shipped on Monday. SpEEdyBL was right on the money with the Kv values. Here is what Bob has just sent me:
"Here are the KV tests I did on the two motors. Input voltage measured at Speed control power input Motor Vin Aload KV 2.5 5.0 3 7900 Free running (no load) 2.5 4.0 30 7125 Loaded 2.5 5.0 43 6960 “ 2.5 6.0 57 6700 “ 2.5 7.0 73 6515 “ 1.5 5.0 9 12,630 Free running (no load) 1.5 4.0 91 9750 Loaded As you can see the 1.5 is pulling a lot of current at 4 volts so I did not want to run it at any high load. My suggestion would be to run the 2.5 for most of your runs and then use the 1.5 for the last few runs in case it blows up. We will ship the motors Monday." |
Have fun with the speed runs! |
Those motors are going to be freakish!:surprised:
I can't wait to see how they perform (I'm really curious as to how hot they'll run). |
If all goes well, will you also be bringing in that 200 amp sensored/sensorless controller as well as your two other models?
I can't wait to see video of these motors. Should be really fun. |
Neato, sounds good. I've always wanted a sensored/sensorless controller that would run cool, didn't cost an arm and a leg, and could handle at least 3s.:lol::yipi:
| All times are GMT -4. The time now is 12:33 PM. |
