I have had very good use out of my 12c 3600mah polyquest cells. Still use them in my supervee boat, 8 cells in a 2s2p config for 4s 7200 mah and around 86amp cont. Plenty for that boat as it only does about 3/4 hp so only needs around 40amps. My reserve does provide better punch though, and the weight does help the boat out, as it is designed to run 12nimh cells.
Now they are old tech, and just as big and heavy as a 5000 25c pack. I prefer the lightest pack I can get away with, as weight makes the biggest difference to vehicle performance. |
That is what I have, the 10 and 12c poly 3600's. I throw them in my f-350 or twarg for hours and hours of playtime. In the pede they don't hold up so well. In the emaxx it is just plain sad.
I like running a higher C rate battery because you are not pushing the cell to its limits. Therefore it will last longer. Not only that, but voltage is more steady.
The only time I use a low C rate battery is if I have high mAh to compensate and want runtime rather than reduced weight. |
Ok,maybe Im looking at this the wrong way.But it seems by combining cells into a large capacity pack the c ratings must go down ,by design of the pack.Because of the increased runtime,and the cells sitting right on each other,you will get increased temps.So it would seem to me that combining the 2 you would have to drop the constant rating to make up for it.So if you used 20c 4000mah cells to make a 20c 8000mah pack,the pack would not actually be capable of that .As the pack itself would have to discharge at either twice the time,or twice the amps,either of which would cause more heat,in pack form.So to over come this they must drop the c rating some,to come up with an accurate pack rating.So because MA uses a single cell rating on there pack,the bigger the pack the further off there ratings became.Then a TRC 10c ,that alot claim are underated,Actually perform that good because to accurately make a 10c 8000mah pack,they use 15c cells,so it actually will do 80amps for 8000mah,but seems to perform better then that . This is just my theory, So please correct me where my thinking is askewed.
I personally don't like the low rate cells on my crawlers. I tend to run hot setups, and I have puffed many 12C 2100 packs. 25C 1300s are my favorite small pack, and 25C 2200s are my favorite larger pack on a crawler.
Did I mention they were almost free? I have maybe 80 bucks in 15 2100 cells, and i may have a spare cell or two laying around... 5 bucks a cell is cheap, considering what they sell for new... If I replace them I have some fp 2170 3s packs that will be used. About the same size and twice as powerful. |
ive been running a 6s 4000 from them for a while now, makes me crazy to get it to hold ballance. sometimes i have to charge one of the cells independantly. a cell went bad and i got another one at cost...... $30. not to mention i paid $239 for it a year ago and its now $299 for the same friggin pack
Considering.
i recently purchased some neu 6s 3200 25/50c packs and they run strong, and STAY balanced. plus i got two for the price of one MA 4000 and they are 70g lighter. less capacity but i use about 1000mah in 8 mins. so i can run two 5-7min quals. with one pack or a 15 min. main
i have always had a hard time keeping the cells balanced as well , so much for matching cells.......
anyway i needed one cell once , bad pack and wanted to rebuild, and was told that i couldnt just put one cell in because the cells are matched and it wont stay balanced......it never did from the get go , but the pack is going strong, as long as i dont discharge below 3.3vpc they have some new hard case packs coming out from what i here , but for the price i will look elsewhere for packs , imho |
| All times are GMT -4. The time now is 12:13 PM. |
