heck yea that looks soooo much better, for the record if the kyosho rears work then so will the b44 or b4 rears....
what do you mean sean? they use a 12mm hex the pin length of size that holds the hex on doesnt matter, if you mean the axle size the b44 or b4 use a 3/16th (4.83mm) axle while the kyosho use a 5mm. either will work as the wheels center hole only sits on the threaded part which is slighty smaller diameter than the shank of the axle where the hex sits....
if you notice any difference between the two it woud be that the b4/b44 wheels would fit slighty tighter. hope that made sense, (because ive used lazer wheels on a b44 and vice versa) |
Wait so the mini e-revo uses a 36mm motor!? My god I might have to get one now.... Run a 4s 2200 mah system with a Medusa and mamba max. Hell Yeah. :yes:
Has anyone tried fitting a 2200 cell in there yet? No, I found it's a 380 motor so a 28mm medusa would have to do. |
http://i904.photobucket.com/albums/a...voDeans022.jpg http://i904.photobucket.com/albums/a...voDeans026.jpg |
damn im a total TARD, i have my b44 sitting right here in front of me the whole time, i must have been thinking about the front being a 12mm hex i completely forgot the rear was pin drive, when we used the b44 wheels on the lazer we removed the hex and on the b44 we added a traxxas hex in the rear.......
:oops: :whistle: |
:lol: |
I just spent the better part of last night cramming a Neu 1112 into my 1/16 E-Revo. I haven't even ran the truck.
I'll be using a Mamba Max ESC in it and will be switching between 2S2P and 4S1P (I bought 2S 2200mah Zipp packs). I'll also be running a Castle BEC. Seems like overkill in a small truck but I guess this is what it takes to have a (extremely overly-) powerful setup that will run ice cool no matter what I throw at it. I had to dremel the rear shock Tower and cut the shaft down on the motor (the Neu shaft was a solid 1/8" too long). I also ground a flat spot. This weekend I hope to fab up the ESC mount (I'm going to make a mount out of aluminum that slides into the stock ESC mount tabs so I can slide my ESC out just like stock). I've also moved my steering servo to the other side to balance the weight and provide cleaner wiring later on. |
I'd love to see pics of that when you're done, BP.
I'm picking one up tonight... I just don't know which to get!
I have two slashes and an E-Revo in the full size, and can't make up my mind on the mini! Help! |
wait till linc sees it....im sure he could have fun with that post, he has fun with most posts :whistle:
I went with the E-Revo. The ground clearance and tires should allow it to go places where the Slash just can't.
FWIW I think a medusa 36-50-5900 with a MM or SW on 2s ~4500mah would be killer.
I stopped by the LHS today and got a look at both the Slash and Revo. At first, I thought they were pretty cool, but after a while, I was less enthusiastic. With a little work, the CRT.5 is pretty darn close size-wise and has beefier driveline. The Revo/Slash shocks looked very chintzy, almost like a Wal-Mart toy. And the VXL, well, it's a VXL. I guess $290 for a true RTR BL system system isn't bad, but I didn't go for it.
Maybe once the eBay chop shops start selling rollers with no electrics, I might get one. |
Picked up a slash to play with. Quite a bit of fun so far - watch your running surface, though! Uneven cracks in our sidewalk are more then enough to bottom it out, and send it flying. If I'd put a little more thought into that, I woulda went with the e-revo, but the slash looked too cool to pass up. I love the corr truck look.
So far I've just swapped out the receiver and put some shims in to remove some wheel slop. Still formulating plans for what else to do... gotta get some 3s batteries that'll fit. I was eyeing the turnigys, just need to do some measuring. Tony |
Got a 52mph pass with the mini revo on 3s, Ya I kno its dark
http://www.youtube.com/watch?v=acEbRRv9pEA |
I got mine in today. It zips around pretty well on 3s. I tightened everything up and put the smaller 23t pinion on. The holes for the battery wires to pass through are too small for 12 gauge wire, so I'll need to open them up a bit.
Things went well until the end of the run. I did a reverse back-flip and broke one of the driveshafts, more specifically the plastic part that connects to the diff. It's cracked on both sides. I wasn't fully expecting to do a back-flip so I was on the throttle when it landed. It's more my fault than the truck's because most drivelines don't like landing with the wheels at full throttle. Oops. I've super-glued the cracks and will take it easy until a replacement gets here. It's definitely a bit smaller and less sturdy than the CRT.5. It needs thicker oil in the shocks for sure. It also needs shimming to tighten the wheels up a bit. Overall, I'm pretty happy with it so far. Good times. |
Wild YFZ. I think you are way overgeared with a 33T on there. If you gear down to about 25T I'm sure your speed will increase.
Anyway, I have an order from Tower which I am hoping will arrive tomorrow, if it does, I'll be able to have pictures of it up. I'm itching to run it. I think I'll borrow my friend's CrapAmps 3S 1100 packs to run in parallel to try it on 3S first. I have a feeling something in the drivetrain is gonna hate me when I run 4S. |
I don't think goin from a 33t to a 25t will increase my speed, Im running 3s lipos wich is around 11.1~ volts and I am seeing 52mph tops, Yet the 12 cell Ni-mh setup running a 23t pinion at 14.4volts is seeing 50, And you all know the speed claims by traxxas are a bit off. So i think 33t is not over geared at all as both the ESC and motor reached 130 from about 10 passes, If i was overgeared the temps wouldn't be the same ( ESC- 123, Motor-132) Also the motor had no trouble pulling that gearing either it still did wheelies like crazy, Actually did a 50mph wheelie and it sounded all fine.
Since my diff yoke broke, I removed the front axles and just made it rear-wheel drive. I was able to get through one run with 23t pinion and the stock battery. The top speed was expectedly low, but it was still pretty fun. I threw in the 3s lipo and that was a perfect bashing speed for me.
Three minutes into the 3s run I ran into a curb and broke the right front upper A-arm. The brakes are much weaker than I am used to. With my other similar vehicles (RC18, Vendetta ST, CRT.5), I can stop from full speed in just a few feet if I need to. With the E-Revo VXL, I wasn't even going full speed. I hit the brakes 10 feet from the curb and it still hit hard enough to brake the A-arm. I'm figuring that has more to do with the ESC than anything else, so a Sidewinder might have to replace the stocker. I am pretty disappointed that my truck has broken twice in 3 runs. I wasn't any harder on it than I am on the rest of my trucks. Hopefully Traxxas will send out replacements on Monday, then I'll know to take it easier on it when it's up and running again. |
Not havong the braking power is mostly due to you tsking the front driveshaft out. No front driveshaft = no front brakes, which is where the most braking is done. All the other vehicles you listed are also 4wd which all brake well because they have front braking. See how fast a Rustler stops, they don't!
I know this is just little off topic, Can someone please give me a measurment of the Mini E-revos shocks ? preferably eye to eye but end to end will work. Exact measurment pleeze!
Thanks in advance ! |
In the Traxxas Manual, it states the eye to eye measurement is 47.75mm.
Thank you for the measurments BP-revo. I had an idea of possibly using TC4 Shocks but they are about 10mm to long. DAM ! Maybe some other Manufacturers TC shocks are shorter ? Circumfrance will also play a part also. |
I would just buy the aluminum bodies and TiNi shafts from Traxxas to make these just like a mini version of the upgraded Revo shocks (that now come standard on the E-Revo). They have proven to be great shocks from my experience with them, and I can't see the mini versions being much different quality wise.
That said, the stock shocks do suck...a lot. I haven't even ran mine and I can already tell that they aren't very smooth and have already leaked a solid amount of shock oil out of them cause there is almost no dampening. |
Just ran mine today on one of my Hyperion G3 packs. Awesome lipos and quite a fun truck! I don't see why anyone would want to bash one of these on anything more than 2S. IMO, it's just a recipe for carnage and more time on the lid than on the wheels. Hell, it's hard enough keeping it on the wheels with 2S and a heavy throttle finger.
Decided to play around with mounting some different tires/wheels on the Slash that I had laying here. I drilled out the axle hole on some mini inferno wheels and put them on. The wheels are Pro-Line mini inferno, tires are Pro-Line Crimefighter and hexes are from 3Racing for a mini inferno. They are almost identical in size to the stock tires/wheels.
http://skellyo.com/fs/vxl_14.jpg http://skellyo.com/fs/vxl_15.jpg |
Wow, That 's looking WAY more track worthy now ?! They look excellent and right at home on your Slashy. I've ben searching for anything for wheel and tire combos for the M-ERevo .
So far looks like the kyosho or B44 rims are the ticket ? Edit: I had to add this; "What a great looking little truck that is !" |
Skellyo, what runtimes are you getting and are you running your 2s in series or parallel or just one pack????
All the local guys have been beating their E-Revo VXL's up pretty good at the track and nothing has broken on theirs so far. I'll give it another shot when the new parts get here. |
Took the slash out to where they're building a local track - right now it's pretty rough dirt, a lot of rocks, and the recent heavy rains left it pretty wet...
That being said, it was a ton of fun! I flipped quite a few times when I hit some rocks, took some amazing tumbles, but didn't break anything. Just some mud to dig out of it. Tons more fun on the dirt then on pavement! I'd had some second thoughts on the slash after running it on pavement, but it really looks amazing on the dirt. Still running the stock battery, debating on either 3s in parrallel or 2s in parallel, when I make up my mind I'll get some on order. Tony |
| All times are GMT -4. The time now is 07:46 PM. |
