-   -   CC Blower now on sale! (https://www.rc-monster.com/forum/showthread.php?t=23573)
simplechamp 09.24.2009 03:00 PM
Allright, here is the new CC Blower!
It is made of all plastic (seems pretty sturdy), so it's only a fan and shroud, no heatsink. The plug is a standard servo plug with red/black wires (no signal wire of course). The wire is a bit smaller gauge than standard servo wire, would have been nice to have a little bit thicker wire.
The shroud over the fan seems to have an intake of sorts, almost like the blower on the hood of a hot-rod. The top of the fan is open so I'm not sure how functional this intake will be, but maybe there is a reason Castle put it on there. If you look at the way the plastic case is shaped it almost looks like they were trying to make it look like a V8 engine (could just be my imagination though)
The fan uses a DC brushless motor. It's rated for 5V and will draw 140mA at that voltage. The fan model number is YM0503PVS1. It has a small logo on the label but I'm not familiar with it, maybe someone can make it out in the picture.
Now I just have to get my E-revo back together so I can actually test this thing!
http://i47.photobucket.com/albums/f1...3/P1020452.jpg
http://i47.photobucket.com/albums/f1...3/P1020453.jpg
http://i47.photobucket.com/albums/f1...3/P1020454.jpg
http://i47.photobucket.com/albums/f1...3/P1020458.jpg
http://i47.photobucket.com/albums/f1...3/P1020456.jpg
http://i47.photobucket.com/albums/f1...3/P1020455.jpg
http://i47.photobucket.com/albums/f1...3/P1020460.jpg
http://i47.photobucket.com/albums/f1...3/P1020459.jpg
sabongi 09.24.2009 03:19 PM
the shroud could be made of aluminum so heat would be dissipated better :(
whitrzac 09.24.2009 04:04 PM
that would cost$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $
BrianG 09.24.2009 04:15 PM
lol, it does look like a V engine... one with a HUGE crankcase. :smile:
emaxxnitro 09.24.2009 05:02 PM
same fan as the mmm. oh well it will work for a while at least
Brushless Moose 09.24.2009 06:17 PM
As much of the motor as it covers up, I worry that it will only add to the heat problems.
brushlessboy16 09.24.2009 06:19 PM
Its flowing more a larger volume of air over that portion of the motor than if it were uncovered.... Soor to shoot down your logic:intello:
Brushless Moose 09.24.2009 08:42 PM
I have one on order to cool y overheating tekin. Temp on the motor after a 15 min. main are over 185F:gasp:
brushlessboy16 09.24.2009 09:16 PM
yikes something isnt right.
Brushless Moose 09.24.2009 10:01 PM
I know. Check out my thread in the tekin forum. I have checked EVERYTHING. It just runs hot!
brushlessboy16 09.24.2009 10:13 PM
sounds like my 2200... killed a 1515 1.5d.. temped close to 270 degrees..
I guess 8ights just dont like running right :lol:
Shark413 09.25.2009 02:42 AM
I recieved a couple of them today and tried them out on various motors to see what they fit. One thing I noticed was it is basically a shroud and relies on the cans cooling fins for output venting. So smooth can motors may not vent as well, or I guess you could drill some holes, but I think the logic was to blow air around as much of the can as possible before venting.
Pictures:
http://i142.photobucket.com/albums/r...castle_neu.jpg
Fits perfectly on a Neu-Castle
http://i142.photobucket.com/albums/r...rk413/1515.jpg
Fits on a finned Neu 1515 perfectly as well
http://i142.photobucket.com/albums/r...rk413/1512.jpg
And a finned Neu 1512 (same diameter)
http://i142.photobucket.com/albums/r...413/1515sq.jpg
Doesn't fit on a 1515 Tekno-Neu square can - Duh
http://i142.photobucket.com/albums/r115/shark413/t8.jpg
Fits pretty good on a Tekin T8
http://i142.photobucket.com/albums/r...rk413/1509.jpg
Fits ok on a smooth can Neu 1509 (a little loose)
http://i142.photobucket.com/albums/r...413/feigao.jpg
Worked ok on a Feigao
http://i142.photobucket.com/albums/r...k413/cms36.jpg
Too big for a Castle CMS36 can
http://i142.photobucket.com/albums/r...ark413/540.jpg
Way too big for a 540 sized can
http://i142.photobucket.com/albums/r...13/venting.jpg
And the only output venting is via the ribs on the can.
big greg 09.25.2009 04:46 AM
man that fan has been around already! what a "$@re lol
austinmaxx 09.25.2009 04:13 PM
lol does it cool much ?
BashemSmashem 09.25.2009 09:00 PM
So do these work or what ? Will they fit the TORK motor ?
simplechamp 09.27.2009 07:02 AM
I don't think so because the Tork has the heatsink in the center which will get in the way.
suicideneil 09.27.2009 08:25 AM
Tork motor has much longer cooling 'pins' vs the shorter fins around the afforementioned motors, so you would have to stretch it so much that it might break/ split.
You could stick the motor in a lathe though I suppose....
BashemSmashem 09.27.2009 09:01 AM
Actually IT DOES fit the Tork motor ! My son just got his and yes you do have too stretch it on kinda but it looks good and works GREAT ! Much cooler now than it was without , though we were only hitting the 140's before , but he wanted it for the cool factor . And I must say , it does look pretty cool !
rchippie 09.27.2009 12:26 PM
Can the fan be turned around in the shroud, so the wire is closer to the reciver & facing the FR of the vehicle ?.
Freezebyte 09.27.2009 02:10 PM
Damn, that definitely won't fit on a Flux. Owell.....
suicideneil 09.27.2009 04:16 PM
Photos please. :rules:
Freezebyte 09.27.2009 09:00 PM
PIcs gundamnit! :whip:
sikeston34m 09.27.2009 09:16 PM
Don't that just drive you Crazy?!!! :rofl:
fastbaja5b 09.27.2009 09:48 PM
http://i212.photobucket.com/albums/c...b/pichers1.jpg
BashemSmashem 09.27.2009 11:29 PM
Sorry , here are a couple of crappy pics ....
http://i469.photobucket.com/albums/r...IMG_0037-1.jpg
http://i469.photobucket.com/albums/r...IMG_0039-1.jpg
It didnt go on easy , but it did go on ...
Freezebyte 09.28.2009 12:11 AM
Uh, thats not for the Flux :neutral:
Patrick 09.28.2009 12:16 AM
He only said it fits the tork motor, he didn't say anything about the flux.
BashemSmashem 09.28.2009 11:38 AM
Exactly :yes:
suicideneil 09.28.2009 03:23 PM
He he he...
Well, looks fine on there, so I stand corrected*
*actually, Im sitting down eating tuna & mayo sandwiches, but anyways...
snellemin 09.28.2009 03:54 PM
Seems like I need one of these blowers for my hot GTP.
needforspeed 10.02.2009 05:30 PM
Just got my blower today,now that cold weather is here lol.
Guess i will find out if it works next summer,Man I hope it warms up
Brushless Moose 10.03.2009 12:07 AM
the blowers are junk if you ask me. It did drop temps by about 15F, but it self destructed after one run. lost a blade, then had a HSCA. (high speed come apart.)
big greg 10.03.2009 03:35 AM
fans:whip::whip:
suicideneil 10.03.2009 01:22 PM
The fan is junk then, not the blower itself- sounds like a familiar issue...
Shouldnt be an issue getting a more durable aftermarket fan for the blower (common size), but the question is do you really want the blower that baddly, or was it just an impulse purchase?... ('that looks cool, I want one...').
simplechamp 10.03.2009 09:28 PM
I pretty much got mine for the "it's cool, I want one" factor. I don't need the blower because my motor stays well within safe temp ranges. On the other hand cooler is always better so if it will bring my temps from 125F to 115F then I'll take it.
adrictan 10.11.2009 12:36 PM
Does anyone know the dimensions of the fan? Can it be removed to replace if the fans spoils?
needforspeed 10.11.2009 01:52 PM
OK, its about 60* outside and I just got back in from my 2nd test run,My temps were 160-175 running in grass (trigger happy) Now with the blower, I max out at 115 and I cant get it any hotter.These temps don't seem realistic. I am using on-board telemetry and a temp gun. So far I love this thing.I am going to do some more testing to confirm these numbers,like I said (unrealistic)
simplechamp 10.11.2009 03:34 PM
I think someone said it's the same fan that is used in the MMM. Shouldn't be any problems replacing it.
Freezebyte 10.11.2009 06:48 PM
I really wish this could fit on my Flux
Unsullied_Spy 10.11.2009 07:02 PM
http://www.frozencpu.com/products/25...l?tl=g36c15s70 :intello:
