Mine came with a coupon for a free castle link adapter. It says to register it with a code provided and they will send a free castle link. They must not have had enough stock to package them with the MPro.
Castle Link adapter chip
The Mamba Max Pro will be coming with a coupon for the Castle Link adapter chip. This entitles you to a free Castle Link adapter chip, but does not include the USB cable; we cover the cost of shipping for domestic addresses and most international shipments. This is also true for the new Phoenix ICE line. You have 3 options for redeeming the code on the coupon. You can submit the code on our website, fill out the coupon and fax it, or simply mail it in.
Just FYI... We stopped including the USB cable with our products. So the Mamba Max and Mamba Monster no longer include the cable. For now the Mamba Monster will still come with the USB adapter chip, but eventually it will be replaced by the coupon as well. Thomas Porfert Castle Tech Support |
That's good, because I only have about 100 USB cables laying around from this that and the other.
Good idea to do it this way. I like that you have decided to cut costs and eliminate redunduncy but still have a way to provide for your customers. Many would just charge for the adapter, yet I will not mention any names of who those people are....... |
man, I still haven't received mine.
I like the coupon idea as well. |
Just got mine from Tower today.
Hello,
I would buy a sensored brushless, but I hesitate between 2 controllers I would like to know if the MMP can handle a T8 2050kV in a Ve8 (weight around 3550g). I know the MMP is not dedicated to that, but in Europe we need this brushless for most of our racetrack. The MMP have a Nice footrpint and I think it can made the work well, but I don't know if it can easily handle this kind of motor (the T8 2050kV is a delta wound that drain more current than the Wye wound) Thanks for your answer |
Is this ESC going to be any good to use as a crawler esc? Or is it too big?
I think on a AX10 or the like it would work fine. It has the same footprint as the MM which many people already use on crawlers. The good thing is that you could remove the fan and save a little more space since crawlers tend to pull such low amps I highly doubt the fan would ever come on.
The sensored/sensorless hybrid mode would be probably bet pretty nice for crawling. |
IE. Where do you request an upgrade? I assume I have to mail the MM back to castle, so do you just fill out a repair request form and note that you want an upgrade to MMP? Right now you can do the online repair request, but its only repair for $50. Perhaps just adding an option to the dropdown menu that requests upgrade only for whatever you will charge ($75) so you can check out and get an RMA number there and put into the queue. Whatever makes sense with your system. I'm just looking for the logistics. Thank you and good luck. Its very nice to see a company so dedicated to customer service and constant improvement. |
mmp
FYI - Ours are scheduled to arrive Friday. :)
Darn it I just tried to order one but it won't let me because its out of stock. :cry::cry::cry:
Its not Friday yet. :)
Out of curiousity, how many did you order?
For now when you fill out the form on the website, just claim it as a non-warranty Mamba Max for $50.00. When you fill in the order form, there is a section for additional information. Just add a note that says "Please upgrade to Mamba Max Pro". Our repair administrator will adjust the cost and change the order to a Mamba Max Pro. We won't charge your card until the replacement is ready to ship, so you can submit your credit card number on the secure order form. After you submit the order, you will get an e-mail confirmation back. Just print off the e-mail confirmation and send it in with the Mamba Max. Let me know if you have any additional questions or concerns. Thomas Porfert Castle Tech Support |
Thinking along the lines of crawlers... what about a Sidewinder Pro? I think if it were only $10-20 more than the current Sidewinder for the added sensor capability and current-spec FETs and brain board it would be a hit.
Thanks for your answer, I will try the MMP |
Personally, the biggest advantage with the MMPro is the 6s capability. I like having a "1s" voltage headroom (for more leeway with braking spikes), so I would run 5s on a lower kv motor. Still gear conservatively and set the MMPro options to be gentle.
I agree with BrianG - a good quality 5s pack should allow the MMP to efficiently and safely provide good power. Time will tell how well it handles 1/8 buggies in the real world, but I tend to believe it should handle 'reasonably sane' 1/8 buggy duty rather well(no doubt there are people that will quickly find a way to kill it). :)
There ya go! If the monster says it is so, then it is so! :smile:
People do run the regular MM in buggies (and the MMPro is pretty similar to the MM in current-handling), so 4s should work fine, but it will get warm. 5s on low kv is the way to go. Or, if you want to use mechanical brakes, run the full 6s and an even lower kv motor (~1300-1500). If you want to retain motor brakes and run 6s, I would solder on an extra TVS/capacitor module to the power wires. |
Brien,
what values would you recommend for the TVS and capacitor? Thanks, Avner. |
For 6s usage, 35v low-ESR caps (you can tell by the 105*C rating). Actual capacitance varies. If I'm gonna add caps, I like to at least double what is currently on there. IIRC, the MMPro has 3x220uF caps (660uF total), so anything around that would work. You could get one cap or 2-3 smaller ones - doesn't matter (although I personally prefer mutiple smaller ones for better heat dissipation and transient response).
The TVS should be similar/same to what Castle puts on the MMM. Can't remember off the top of my head the exact part number though. Or, you could get something like this: http://www.shopatron.com/products/pr...ber=5685/135.0 |
And if you decide to run low turn motors buy two or three of the Novak ones, if you can't build your own.
Or was that a problem with the beta units? |
Has nothing to do with it having a fan or not. :tongue:
5s is the new 6s, its a fashion thing, all the cool guys are going this route ... :wink:
Well guys the MMPs are up and available for purchase in the RC-Monster store, I just ordered mine, can't wait to try it.
I can't wait to try mine too!
Ok. I have heard of people getting these in already. So, does anyone have any info on the following usage of the MMPro:
- 4S 1/8 Buggy - 1900Kv - 2200Kv motor (sensored info preferred but sensorless good too) |
I much prefer 5s to 4s lipo, the amp draw is considerably less, and everything just seems to run alot cooler. Plus you can get away with lower spec batteries if you desire, or just not push good batts as hard (they last longer that way). |
Got mine today:
http://i798.photobucket.com/albums/y...027_0180-1.jpg |
Is anyone else having probs with the MMP when useing JR servos??
I have a 650m that causes the esc to flash lights, the light on the RX blinks, and the servo twitches to the right... BTW the servo works fine on my RX8, and MM |
what type of rx are you using?
Does the problem occur when using a different servo?? If it does, then it's a problem with the Pro. If it only does it with that servo, it's a little more puzzling, especially since that servo works on other setups. Let me know if you get any different results. Thomas Porfert Castle Tech Support |
| All times are GMT -4. The time now is 09:28 PM. |
