Oh.. and I ran the 30 minute main... should have been almost 32 minutes total track time. The 8000pack charged back 5440mah... 170mah per minute.
I wish I could always count on that! The 5000mah pack just might have done it if I skipped the warm up laps!!!! I should have run the 5000 pack.... the car would have handled better too so maybe I would have done better. One last thing: With the 8000mah pack it weighs about 2oz. more than my buddy's nitro 8ight full of fuel. He also has a heavier body... probably a good 2oz more than the stock one. With the 5000mah pack it only weighs 7lbs 3.6oz... a full half pound less than the nitro. I did see another guy on rctech say his (nitro) 8ight weighs 7lbs 3.3 oz wihtout fuel (would be @7lbs 7.5oz. with full tank). The 8ight is so light, some guys are putting lead weight in the rear... but it's cool to have an BL that weighs less than a nitro and can run almost 30 min. |
glassdoctor,
Could you give us any more information about your setup, other than what's in your signature. I'm just getting into the world of BL conversion, and I like to see as many examples as I can, in as much detail as possible, of good conversions. Also, could you post some recent photos, or point us to some that are already online? Thanks again for your patience. |
http://www.rc-monster.com/forum/showthread.php?t=5572
start there.... plenty of stuff to look at.... |
By the way, glassdoctor, would you recommend the Mamba Max/New 1512 combination? I'm thinking I'll probably use a 1512 on my buggy project.
Oh, I see you just replied to my previous query. Thanks. |
Hmmm.. that's a big topic here... the MM and Neu combo.
I'm doing it... but it's tough to recomend it due to the potential cogging problems. EDIT: I did just take the MM out of the CRT and put in a 125b... which seems buttery smooth. With the motor wires direct soldered, I'm having pretty good results. But there is still a bit of cogging occasionally. So far it's not bad and I could recomend it if the other advantages outweigh this flaw. But I'm concerned that a bad episode of cogging could ruin a MM. That happened to me recently. (before removing the 4mm connectors and hardwiring it) IF Castle comes through with a software update to fix it... then I will absolutely recomend this setup to everyone! BTW, I have heard from more than one person that the MM works awesome with a Pletty Maximum... zero cogging so they say. So i have faith that CC can fix this issue. |
| All times are GMT -4. The time now is 12:11 PM. |
