Does the sidewinder have a usb port like the mamba max? |
-J |
yeah, through the castle link you can upgrade it.
Someone like Mike, the owner of RC-monster you mean?
Yes, the Castle link is the programming software and the adapter needed for programming the Sidewinder. Since the Sidewinder has no usb port the Castle link adapter is used on the RX plug. |
Thanks :D -Jeff |
Yes, it is programmable through the PC: http://www3.towerhobbies.com/cgi-bin...&I=LXGVR8&P=ML. This is the castle link used on almost all castle's products, except Mamba max (USB)
From my understanding reading a few reviews and PPl's trials this ESC does have the newer firmware, or better than the MM for running other Mfg's motors such as Novak (sensored mainly) which the Mamba max was horrible at. But, it doesnt run brushed motors right now until a firmware patch is realeased. Personally, mine will never see a brushed motor so updating right away isnt totally necessary. |
Wow, I'm so tempted. This would be perfect in my DF03.
Who's gonna be the first to try it on 4s ? lol. J. |
Just updated my MM, loving the "dead band" adjustment. It's been the only thing I wish I'd have had before now. Mabey torque and RPM limiting software, so I could throw the extra MM and 5700kv I've got into sons XXXT without buying tons of replacement parts for every time he crashes at those speeds :) I have learned to use smaller KV motors with good results on small tracks.
Reverse rolling to forward power is better too. It never cogged on my setup but you could hear just a little chatter from the slop in the drivetrain which is gone now, just at startup. |
Just kidding! I am looking for a decent motor around 2500kv to use 4s with this esc in a crt.5 or LS10. I have a lehner basic xl 2400, but maybe that motor will be too much? |
someone try this with an outrunner!! I need to know how it works, if the update helps. This update is the same for the sidewinder and the MM ?
J. |
I'm going to try it with my truck. It has a Neu 1521/1Y and I'm going to use 4S with it.
I did try it in my MBX5T with a Mega ACn22/30/2 and it was much smoother before this update, but for some reason it is not smooth at all in my TC3 with the Trinity N80.
Go under "downloads" and then Mamba max history: www.castlecreations.com
It helps to open the castle program first, well atleast with Vista it detects an update. Something new to tinker with. |
Anyone got it working with Vista x64 ?
I guess I'll try tonight.... |
:intello: Who needs 64 bits anyway.. 16gb of internal memory?
No only 4GB... :)
Mild gaming rig... 3.2Ghz Core 2, 8800gtx, 4gb... It is cheap now so why not... only think that doesn't work now is the CC software :( |
That would actually be a nice set up for gaming on a laptop. I would hope your laptop has a cooling pad. |
No thats a desktop with large widescreen monitor - laptop is for work so as small and as light as possible... Odd though that the CC wouldn't work on the laptop either - need to try a clean install again for track side changes...
I dual boot the desktop to XP at the moment - Wifes going to be please about 5 cars coming upstairs tonight for software updates! LOL! Into the old computer thing so LMK if anyone needs upgrade or build help. Rgds |
What Feigao motor would you use with the Sidewinder in a Rusty on 2 cell Lipo or 8 cell NIMH? |
ok, thanks for the advice
So.. I found an RC10T in my garage.. and decided that was good enough reason to buy a sidewinder :) Got it on the way Priority along with a few 10T parts. Yipee! Also ordered some stuff from Mike for my 8ight :) should post some photos in a week or two!
-Jeff |
Which motor would be the better choice for a Sidewinder in a CRT.5 the 4600 or 5700. I just want to buy the combo for playing around in the street and at the park, just not sure which motor. Pinion gear too, not sure on that, just looking for some speed and to be able to bash around on a desert like terrain.
Thanks. |
What battery will you be using? The 4600 should be ok with 3s lipos, but the 5700 would be better for 2s lipos.
Yeah I forgot to mention I will most likely use the MaxAmps 2s 5000mah.
You could go with the 5700, but if you ever want to go 3s, I would get the 4600. 4600 is more efficient. You could gear the 4600 up a bit too.
Just got my Sidewinder 5700 combo. In Castle's manual and on the sticker on the motor it says 3S Lipo max. Guess it can handle 3S LiPo's.?
| All times are GMT -4. The time now is 01:01 PM. |
