-   -   Direct Drive to Diff E Revo Build (https://www.rc-monster.com/forum/showthread.php?t=8536)
lincpimp 02.15.2008 02:19 PM
The spiral cur bearings are a good idea, they should last longer than a strait gut gear, as the teeth are in engagement more than on straight cut gears. The bearings need to ge conical like a full size car, and they need some sort of preload, like a crush sleeve. Most likely would be too big to work well in the space available.
Good luck with the straight cut gears, hopefully they will treat the bearings better than the spiral ones did!
sikeston34m 02.15.2008 09:59 PM
Yes I think the spiral cut bearings are a good idea too. The only downfall is the lack of the correct bearings to work with them. (Please keep in mind that for a regular setup using a slipper, and/or a center diff, the spiral cut gears would work great)
I got the 13/43 gears installed. I took the Revo outside to give it a test spin as best I could. They are going to work! :yipi:
First I tried it on 4S. Much to my surprise it doesn't cog. It does feel like the ESC tries to run off and leave the motor if you just stab it though. (too fast of an acceleration rate in the programming I think) If you ease into the throttle, it runs VERY good. Top speed is MUCH better and the Wye Termination has the torque to pull it to some great acceleration.
Then I had to try it on 6S. The issue that I spoke of on 4S is gone. This is going to be hard to control. It's got some crazy power. I can't imagine what the top speed is going to be, But it hauls! :great: It will wheelie at speed too.
I couldn't get too much into it because it's very dark out there. LOL
I believe these gears are loading the bearings the way they were meant to be. I think we're there.
I'll try to get some video's tomorrow. :yipi:
sikeston34m 02.15.2008 10:44 PM
Ok, the next weak link that I see is:
Is there a set of Revo Diff to Wheel cvd's that are compatible with the regular Hot Bodies Diff cup?
I have the RCM 6mm conversion shafts installed. These allow me to use the Revo Driveshafts from Diff to wheel.
I'm twisting them like a Barber Pole. The hardened steel pin that secures the Revo Shaft to the Diff is elongating the hole. The flat part is twisting. This will eventually give way to metal fatigue.
On 6S, I'm going to need some tough cvd's on the rear. I think the Hot Bodies diff cups may be stronger since there is more steel there. That is, IF I can locate a Revo cvd that will work with them. :yes:
lincpimp 02.16.2008 02:54 AM
I can tell you that the THS cvds will not fit the hb diff output cups. I would think that most revo cdvs would work, as they have the same size ends as an emaxx cvd. Someone here should know!
