-   -   My new home made center sliperential (https://www.rc-monster.com/forum/showthread.php?t=10651)
Just go Play 03.19.2008 03:48 AM
Originally Posted by MetalMan (Post 156101)
Like this?
http://smg.photobucket.com/albums/v132/4x4pede/Revo/ (lincpimp is the current owner)
That is a nice compact setup and it looks to shift the weight off the rear end... hmm gears turning now. Is there a noticeable difference in how the CD acts when the motor is mounted center chassis as opposed to the stock location?
I don't want to jack this thread so MetalMan if you could pm me I'd like to pick your brain a bit if possible?
david lamontagn 03.19.2008 03:39 PM
The only problem that i can see for now on my system is the gear mesh between the 22T pinion on the sliiper shaft and the spur gear on my spur adaptor.
The mesh seam to be a liitle slack, but not sure.
If i hold the spur and i try to move the 22T pinion, i can move the pinion back and forth a little bit, but for sure, it's little more than if i was adjust the mesh with a piece of paper.
And you know, i can't re-adjust them:whistle:
To re-adjust them i have to make another complet mount........................
Anyway, i'll try it like that and if it's too slack, probaly i'll break the spur or the pinion.
Arct1k 03.19.2008 05:55 PM
You could try a 23T?
lincpimp 03.19.2008 06:02 PM
Hey david, do you think a 23t pinion would be too tight? Might fit and mesh nicely?
david lamontagn 03.19.2008 08:37 PM
A 22T is 24mm diameter, and the 23T should be 25mm.....Hummmmmm!!! it's a full 0.5 mm all around, so i think that it'll be to tight, but if somebody have a 23T for me, i'am ready to try it.
Because i don't want to order just a pinion from Mike, it'll cost $25.00 just for shipping:lol::gasp:
I've try the gear mesh with a Kyosho 46T plastic spur and it was not to bad, but with the steel one, the mesh seam to be a litle on the loose side.
Maybe it's the theet shape of the steel one that's not the same.
lincpimp 03.19.2008 08:41 PM
It may be ok, I usually set my steel to steel gears slightly looser than stell to plastic. They seem to run smoother with a bit more slack, and are plenty strong.
david lamontagn 03.19.2008 09:06 PM
That's what i think, so i'll be try it.
But your idea of a 23T is not bad, i'll try to find a 23T just to test the mesh!
lincpimp 03.19.2008 09:11 PM
Hope it works well, let us know!
Cowboy 03.20.2008 12:31 PM
Originally Posted by Just go Play (Post 156086)
Speaking for myself I find that the revo center diff is worthless when running a powerful BL motor. Too much power gets wasted due to excessive power going to the front wheels spinning instead of to the ground.
I need to pick up a 1/8 diff to play with to see if I can get the diff action under control. After seeing David's setup I may try something similar but fitted with the center diff.
I was building 1/8 scale revo center diffs before traxxas came out with their own. They were based on a thunder tiger ttr s3 buggy diffs and they worked awesome. I still have some parts and blue prints if anyone is interested. You can pm me for pictures.
